Benchmark Settings:
Tool: FIO
Benchmark Type: Performance Spectrum
File Size 10GB
IO Depth: 16
Runtime: 120
sudo zpool status
pool: TESTZ2
state: DEGRADED
status: One or more devices are faulted in response to persistent errors.
Sufficient replicas exist for the pool to continue functioning in a
degraded state.
action: Replace the faulted device, or use ‘zpool clear’ to mark the device
repaired.
config:
NAME STATE READ WRITE CKSUM
TESTZ2 DEGRADED 0 0 0
raidz2-0 DEGRADED 0 0 0
1-9 ONLINE 0 0 0
1-10 ONLINE 0 0 0
1-11 FAULTED 0 21 0 too many errors
1-12 ONLINE 0 0 0
1-13 FAULTED 0 17 0 too many errors
1-14 ONLINE 0 0 0
1-15 ONLINE 0 0 0
errors: No known data errors
Syslog I/O Errors
blk_update_request: I/O error, dev sdc, sector 427221816 op 0x1:(WRITE) flags 0x700 phys_seg 21 prio class 0
blk_update_request: I/O error, dev sdc, sector 63964080 op 0x1:(WRITE) flags 0x700 phys_seg 100 prio class 0
blk_update_request: I/O error, dev sde, sector 495373840 op 0x1:(WRITE) flags 0x700 phys_seg 74 prio class 0
sudo smartctl -x /dev/sdc
smartctl 7.1 2019-12-30 r5022 [x86_64-linux-4.18.0-513.9.1.el8_9.x86_64] (local build)
Copyright (C) 2002-19, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Vendor: HP
Product: MB8000JFECQ
Revision: HPD7
Compliance: SPC-4
User Capacity: 8,001,563,222,016 bytes [8.00 TB]
Logical block size: 512 bytes
Physical block size: 4096 bytes
Rotation Rate: 7200 rpm
Form Factor: 3.5 inches
Logical Unit id: 0x5000c50085bd9beb
Serial number: ZA13MJHZ
Device type: disk
Transport protocol: SAS (SPL-3)
Local Time is: Sat Dec 9 14:39:21 2023 AST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
Temperature Warning: Enabled
Read Cache is: Enabled
Writeback Cache is: Disabled
=== START OF READ SMART DATA SECTION ===
SMART Health Status: OK
Current Drive Temperature: 26 C
Drive Trip Temperature: 60 C
Manufactured in week 31 of year 2016
Specified cycle count over device lifetime: 50000
Accumulated start-stop cycles: 94
Specified load-unload count over device lifetime: 600000
Accumulated load-unload cycles: 1879
Elements in grown defect list: 0
Error counter log:
Errors Corrected by Total Correction Gigabytes Total
ECC rereads/ errors algorithm processed uncorrected
fast | delayed rewrites corrected invocations [10^9 bytes] errors
read: 0 0 0 0 0 19758.685 0
write: 0 0 0 0 0 40455.634 0
Non-medium error count: 178
SMART Self-test log
Num Test Status segment LifeTime LBA_first_err [SK ASC ASQ]
Description number (hours)
1 Background long Completed - 41675 - [- - -]
Long (extended) Self-test duration: 45300 seconds [755.0 minutes]
Background scan results log
Status: scan is active
Accumulated power on time, hours:minutes 41750:50 [2505050 minutes]
Number of background scans performed: 581, scan progress: 98.55%
Number of background medium scans performed: 581
Protocol Specific port log page for SAS SSP
relative target port id = 1
generation code = 14
number of phys = 1
phy identifier = 0
attached device type: SAS or SATA device
attached reason: unknown
reason: unknown
negotiated logical link rate: phy enabled; 12 Gbps
attached initiator port: ssp=1 stp=1 smp=1
attached target port: ssp=0 stp=0 smp=0
SAS address = 0x5000c50085bd9be9
attached SAS address = 0x500304801d01d40e
attached phy identifier = 2
Invalid DWORD count = 75
Running disparity error count = 74
Loss of DWORD synchronization = 166
Phy reset problem = 0
Phy event descriptors:
Invalid word count: 75
Running disparity error count: 74
Loss of dword synchronization count: 166
Phy reset problem count: 0
relative target port id = 2
number of phys = 1
phy identifier = 1
attached device type: no device attached
reason: unknown
negotiated logical link rate: phy enabled; unknown
attached initiator port: ssp=0 stp=0 smp=0
SAS address = 0x5000c50085bd9bea
attached SAS address = 0x0
attached phy identifier = 0
Invalid DWORD count = 0
Running disparity error count = 0
Loss of DWORD synchronization = 0
Invalid word count: 0
Running disparity error count: 0
Loss of dword synchronization count: 0
