This has been an extremely disappointing and frustrating experience, so I’ve got to the point that I am going replace Rocky Linux and Houston with TrueNAS.
I had to ssh onto the server to start cockpit, Samba and cockpit-packagekit.noarch weren’t installed.
Installing packagekit allowed me to update the system, which resulted in 421 packages being installed, although machine was less than a week old. So an ancient image is being used to install new machines.
The HL15 isn’t a desktop but the XServer is running, even Firefox and Thunderbird are installed, no idea why. It’s not as though someone is going to run this, with it’s 6 fans blowing away, as a desktop pc.
And now I can’t access the server via SMB, somehow it thinks it should bind to virbr0.
I’m sorry to hear about your experience with the HL15.
We aimed to deliver an all-around OS for multiple uses for customers of all types, whether that be someone who wants to use this as a NAS or a workstation.
The master image we utilized was created and updated just before we released the HL15. However, due to the overwhelming demand and continuous production, we haven’t had the opportunity to pause production and update the master image.
As for Firefox being installed, this is the default web browser that Rocky ships with and is not something we install after the fact. Most of the preinstalled packages on the server are from our default Rocky 8 desktop ISO.
The virbr0 is a virtual interface created when the tab of the virtual machine is installed in the cockpit. If you wish to remove this interface, you can simply remove the cockpit-machines and then adjust it in the networking section.
SMB, by default, does not bind to a specific interface and instead listens on all interfaces, so the virbr0 should not be causing any issues with SMB.
Could you provide more details about the SMB issue so that we can assist further? Your input is invaluable in helping us address any concerns you may have.
Load smb config files from /etc/samba/smb.conf
Unknown parameter encountered: "includes"
Loaded services file OK.
Weak crypto is allowed by GnuTLS (e.g. NTLM as a compatibility fallback)
Server role: ROLE_STANDALONE
# Global parameters
[global]
printcap name = cups
registry shares = Yes
security = USER
workgroup = SAMBA
idmap config * : backend = tdb
cups options = raw
include = /etc/cockpit/zfs/shares/Main_Backups.conf
[Backups]
comment = ZFS: Main/Backups
include = /etc/cockpit/zfs/shares/Main_Multimedia.conf
path = /Main/Backups
read only = No
[Multimedia]
comment = ZFS: Main/Multimedia
path = /Main/Multimedia
read only = No
[homes]
browseable = No
comment = Home Directories
inherit acls = Yes
read only = No
valid users = %S %D%w%S
[printers]
browseable = No
comment = All Printers
create mask = 0600
path = /var/tmp
printable = Yes
[print$]
comment = Printer Drivers
create mask = 0664
directory mask = 0775
force group = @printadmin
path = /var/lib/samba/drivers
write list = @printadmin root
Output of cat /etc/samba/smb.conf:
# this config was generated by cockpit-file-sharing after importing smb.conf
# original smb.conf location:
# '/etc/samba/smb.conf' -> '/etc/samba/smb.conf.bak'
[global]
include = registry
# COCKPIT ZFS MANAGER
# WARNING: DO NOT EDIT, AUTO-GENERATED CONFIGURATION
include = /etc/cockpit/zfs/shares.conf
Output of cat /etc/samba/smb.conf.bak:
# See smb.conf.example for a more detailed config file or
# read the smb.conf manpage.
# Run 'testparm' to verify the config is correct after
# you modified it.
# Note:
# SMB1 is disabled by default. This means clients without support for SMB2 or
# SMB3 are no longer able to connect to smbd (by default).
[global]
workgroup = SAMBA
security = user
passdb backend = tdbsam
printing = cups
load printers = yes
cups options = raw
# Install samba-usershares package for support
include = /etc/samba/usershares.conf
# inclusion of net registry, inserted by cockpit-file-sharing:
include = registry
[homes]
valid users = %S, %D%w%S
browseable = No
read only = No
inherit acls = Yes
[printers]
path = /var/tmp
printable = Yes
create mask = 0600
browseable = No
[print$]
create mask = 0664
Could you remove the “include = /etc/cockpit/zfs/shares/Main_Multimedia.conf” from under the Backups share and under global?
Also to make things simple could you also remove the “homes”“printers”“print$” shares and the below from the smb.conf
Can you then make your shares using the cockpit-file-sharing tab and not in the ZFS tab. the shares in the ZFS manager tab are not used and we have since made the file-sharing tab instead
I have no idea where Samba is getting all from, it sure isn’t from smb.conf.
cat /ets/samba/smb.conf
[global]
include = registry
testparm -s
# Global parameters
[global]
security = USER
workgroup = SAMBA
cups options = raw
[homes]
browseable = No
inherit acls = Yes
read only = No
[printers]
browseable = No
create mask = 0600
path = /var/tmp
printable = Yes
[print$]
create mask = 0664
[Multimedia]
read only = No
[Backups]
read only = No
# Global parameters
[global]
security = USER
workgroup = SAMBA
cups options = raw
[homes]
browseable = No
inherit acls = Yes
read only = No
[printers]
browseable = No
create mask = 0600
path = /var/tmp
printable = Yes
[print$]
create mask = 0664
[Multimedia]
read only = No
valid users = 45drives
[Backups]
read only = No
valid users = %D%w%S %S 45drives
[global]
include = registry
The ZFS Manager injected itself when I opened to the ZFS tab.
once this is done can you then remove the include ZFS lines from the SMB.conf
Also in the filesharing tab can you make sure there is nothing specified in the global section? Our filesharing tab uses netconf to configure the shares so running “netconf list” will show all the options and will show what the filesharing tab is adding to the SMB configuration.
If you wish to use the CLI you can also export the net conf into a file then edit the file and import it back again with the following
# export to a file
net conf list > file
# edit the file
vim file
# importing the file
net conf import file
