Bill
November 30, 2023, 4:39pm
21
ZFS Cockpit now matches.
ZFS lines in smb.conf removed. and SAMBA restarted.
I only added the shares, nothing was changed:
netconf list
-bash: netconf: command not found
net conf list
Unknown parameter encountered: "includes"
[global]
security = user
passdb backend = tdbsam
printing = cups
printcap name = cups
load printers = yes
cups options = raw
workgroup = SAMBA
include = /etc/samba/usershares.conf
[homes]
comment = Home Directories
valid users = %S, %D%w%S
browseable = No
read only = No
inherit acls = Yes
[printers]
comment = All Printers
path = /var/tmp
printable = Yes
create mask = 0600
browseable = No
[print$]
comment = Printer Drivers
path = /var/lib/samba/drivers
write list = @printadmin root
force group = @printadmin
create mask = 0664
directory mask = 0775
[Multimedia]
path = /Main/Multimedia
guest ok = no
comment =
read only = no
browseable = yes
valid users = "45drives"
[Backups]
path = /Main/Backups
guest ok = no
comment =
read only = no
browseable = yes
valid users = "%D%w%S" "%S" "45drives"
Error is the same. Rebooting after all the changes didn’t help either.
In the advanced option of the global section can you remove the line include = /etc/samba/usershares.conf and then restart SMB?
We need to remove that warning on testparm before SMB is going to work for us I believe.
Bill
November 30, 2023, 5:59pm
23
I tried that and get the following error:
Failed to apply global settings
net: Unknown parameter encountered: “includes”
Error: given parameter ‘include’ is not set. (255)
and the values remain unchanged.
Bill
November 30, 2023, 6:03pm
24
I removed it wit samba-regedit
Bill
November 30, 2023, 6:06pm
25
systemctl restart smb.service
Still broken.
This is now clean net conf list
[global]
security = user
printing = cups
load printers = yes
cups options = raw
workgroup = SAMBA
[homes]
browseable = No
read only = No
inherit acls = Yes
[printers]
path = /var/tmp
printable = Yes
create mask = 0600
browseable = No
[print$]
create mask = 0664
[Multimedia]
guest ok = no
comment =
read only = no
browseable = yes
[Backups]
guest ok = no
comment =
read only = no
browseable = yes
Bill
November 30, 2023, 6:11pm
26
The SFP+ ports are LAG bonded with 802.3ad, but I don’t that it should matter.
Now that the include lines are gone are you still getting the same thing in Samba? if so I would suggest setting the log level to 4 and tail the SMB log while you try to connect to see if that indicates the issue
Bill
November 30, 2023, 6:37pm
28
Error persists, log:
[2023/11/30 19:35:39.809853, 0] ../../source3/smbd/smb2_service.c:749(make_connection_snum)
make_connection_snum: canonicalize_connect_path failed for service Backups, path /Main/Backups
[2023/11/30 19:35:39.809918, 3] ../../source3/smbd/smb2_server.c:3964(smbd_smb2_request_error_ex)
smbd_smb2_request_error_ex: smbd_smb2_request_error_ex: idx[1] status[NT_STATUS_BAD_NETWORK_NAME] || at ../../source3/smbd/smb2_tcon.c:151
find /Main/ -ls
34 1 drwxr-xr-x 4 root root 4 Nov 28 07:49 /Main/
34 1 drwxr-xr-x 2 root root 2 Nov 28 07:49 /Main/Backups
34 1 drwxrwxr-x 2 45drives 45drives 2 Nov 30 03:42 /Main/Multimedia
root 11468 0.0 0.0 419532 25168 ? Ss 19:02 0:00 /usr/sbin/smbd --foreground --no-process-group
root 11473 0.0 0.0 410248 11188 ? S 19:02 0:00 \_ /usr/sbin/smbd --foreground --no-process-group
root 11474 0.0 0.0 410248 4360 ? S 19:02 0:00 \_ /usr/sbin/smbd --foreground --no-process-group
root 11500 0.0 0.0 426228 19992 ? S 19:04 0:00 \_ /usr/sbin/smbd --foreground --no-process-group
Bill
November 30, 2023, 6:45pm
29
Maybe the share defaults aren’t right?
I see whats going on. Your tryting to use SMB2 to connect to the server.
Add
[Global]
min protocol = SMB2
Then restart SMB and try again
Bill
November 30, 2023, 7:05pm
31
Same result:
[2023/11/30 20:02:42.482042, 0] ../../source3/smbd/smb2_service.c:749(make_connection_snum)
[2023/11/30 20:02:42.482076, 3] ../../source3/smbd/smb2_server.c:3964(smbd_smb2_request_error_ex)
net conf list
[global]
security = user
printing = cups
load printers = yes
cups options = raw
workgroup = SAMBA
log level = 4
server min protocol = SMB2
[homes]
browseable = No
read only = No
inherit acls = Yes
[printers]
path = /var/tmp
printable = Yes
create mask = 0600
browseable = No
[print$]
create mask = 0664
[Multimedia]
guest ok = no
comment =
read only = no
browseable = yes
[Backups]
guest ok = no
comment =
read only = no
browseable = yes
Can you try to remove the capitals in the share and make a new path without capitals? Linux is case sensitive whereas Windows is not as much so that could be causing it.
The error also says the following from the log:
Bill
November 30, 2023, 7:46pm
33
From linux:
[2023/11/30 20:44:26.987738, 0] ../../source3/smbd/smb2_service.c:749(make_connection_snum)
make_connection_snum: canonicalize_connect_path failed for service backups, path /Main/Backups
[2023/11/30 20:44:26.987879, 3] ../../source3/smbd/smb2_server.c:3964(smbd_smb2_request_error_ex)
[2023/11/30 20:44:26.988121, 3] ../../source3/smbd/smb2_server.c:3964(smbd_smb2_request_error_ex)
smbd_smb2_request_error_ex: smbd_smb2_request_error_ex: idx[1] status[NT_STATUS_NETWORK_NAME_DELETED] || at ../../source3/smbd/smb2_server.c:3253
From Windows 10:
[2023/11/30 20:46:06.837423, 0] ../../source3/smbd/smb2_service.c:749(make_connection_snum)
[2023/11/30 20:46:06.837455, 3] ../../source3/smbd/smb2_server.c:3964(smbd_smb2_request_error_ex)
Bill
November 30, 2023, 7:56pm
34
Is it a permissions error?
# find /Main/ -ls
Switches in “File Sharing”
root:root on /Main/Backups ?
This doesn’t seem to do anything:
Bill
November 30, 2023, 8:00pm
35
Linux on the client sees everything as far as I can tell:
$ smbclient -L //hl15 --user=45drives --workgroup=SAMBA --password=********
Can't load /etc/samba/smb.conf - run testparm to debug it
Sharename Type Comment
IPC$ IPC IPC Service (Samba 4.18.6)
print$ Disk Printer Drivers
backups Disk
multimedia Disk
45drives Disk Home Directories
SMB1 disabled -- no workgroup available
Bill
November 30, 2023, 8:11pm
36
Is HL15 not the SMB server name?
smbclient \\HL15\backups -I 192.168.76.102 --user=45drives --workgroup=SAMBA --password=******** -l
tree connect failed: NT_STATUS_BAD_NETWORK_NAME
Bill
November 30, 2023, 8:15pm
37
Still broken with
[global]
security = user
printing = cups
load printers = yes
cups options = raw
workgroup = SAMBA
log level = 4
netbios name = HL15
what is the hostname on the system?
I would suggest removing anything with capital from SMB and then trying.
Bill
December 1, 2023, 5:41pm
39
Name is unchanged: hl15
Already renamed to “backups” “multimedia”
Home directory “45drives” fails the same way.
Bill
December 1, 2023, 6:32pm
40
Correction, 45drives fails with:
[2023/12/01 19:30:55.737530, 3] ../../source3/smbd/smb2_server.c:3964(smbd_smb2_request_error_ex)
smbd_smb2_request_error_ex: smbd_smb2_request_error_ex: idx[1] status[NT_STATUS_ACCESS_DENIED] || at ../../source3/smbd/smb2_create.c:340
