TrueNAS in a HL4? Let's talk hardware while 45D build my Chasis!
I just bought an HL4 and I am very excited about it. I would love any advice folks have about the hardware I bought to put in it.
I am still running FreeNAS from 2 or 3 years ago and wanted to do a much needed upgrade. I am about to travel around a lot and I am taking my NAS with me. In my truck / camper. Living my dream! Currently I have low capacity spinning rust in a Full tower case I was able to cram drive caddies into. A raven V2 case I think it is. I wanted to upgrade to a smaller case and hopefully lower power consumption by running more SATA SSDs then spinning rust. I also will need to move this thing around frequently so SSDs are much lighter. I will be sacrificing storage space. However, I am not using as much as I thought I would when I made my current NAS build in 2015 or so.
Purpose of server is to serve up media with TrueNAS scale stable. Other things; Home Automation, NVR as a VM, ISCI block storage for Steam storage. Home lab stuff with VMs. Running Linux systems to test them out. Running Docker tools etc. My new case will have 4 Drive bays that can take Full 3.5 rusts or the smaller SSDs (with adapters). The mobo I chose has a spot for an Nvme drive to use for TrueNAS scale boot. No redundancy on the boot drive. I don’t need 99% up time. In fact I will probably power the NAS off frequently when it is not in use. This NAS will be on the move.
After reading TruNAS forum for several days and looking up many options. Here is my build. Comments and Advice are helpful!! Thank you in advance! I will try my best not to ramble and just give relevant facts. This will be my 3rd Free/TrueNAS build.
Case:
45Drives HL4 With Power Supply and backplane. The data cables I choose are SATA. SFF8643 4x 7 pin SATA. (100% full price)
Motherboard
AsRock Rack X570D4I-2T (Open box special!)
CPU
RYZEN 5 PRO 5650GE (I WILL report if it ECC yes or ECC no as the TrueNAS forums were not terribly clear. Found one used!)
CPU cooler
Noctua NH-l9i Low Profile 37mm CPU Cooler with Heatsink PWM Intel LGA 1151 1150
(Someone was selling a used one!! Nice!)
RAM
NEMIX RAM 32GB (1X32GB) DDR4 2666MHZ PC4-21300 2Rx8 1.2V CL19 260-PIN ECC SODIMM Compatible with Samsung M474A4G43MB1-CTD ECC Unbuffered (so it’s not samsung, hopefully a decent clone… good price)
Network
The mobo comes with 2 10 gig copper Nics (rj-45) but I got short, very short cable runs. I am moving into a tiny trailer (I want to be Chris Farley and live in a VAN down by the RIVER!)
Microtek 10 gig 4 port switch, SFP+ . 3x SFP+ to RJ-45 adapters
Main PC (gaming and work… high amount of data transfers) has a 2 port 10 gig Chelso card SFP+
I have some unifi switches that are just 1gig but they are not doing the bulk of the data xfers. I will be getting rid of those soon.
Lastly I have a Blackhawk router that is a bit outdated? It has an SFP or SFP+ port? only 2.5 gig but it might connect to the NAS quickly? Another thing to test. For the road I will probably find a much more energy efficient method for wifi.
Storage (on current NAS ~ approximately ~)
5x 3TB WD Red drives 5600
3x 4TB WD Red drives 5600
2x 128GB Sata SSDs for cache. I hope they are the right kind, I may not put this into the new build? I have not notice a difference in using them. I have watched 4 hour lectures on ZFS and still fail to completely understand when those cashes become helpful? Perhaps the way I use my NAS just doesn’t benefit??
3x 4TB HGST Enterprise storage drives that spin faster, 7200 maybe?
1x Sata Dom for boot.
Please note this is all being downsized and migrated, I also have a ton of 1 TB Sata SSDs I may start with that? Or I might buy 4 2TB sata SSDs. I would love help to decide? Price per TB I have not quite looked into yet cause I can migrate my pools that direction. I have some time before I hit the road nomad like.
I am considering taking up that PCIe gen 4 x16 slot with a 4x Nvme card. I am fairly certain the Asrock supports bifurcation of the Pcie. I hope I don’t have to buy a card with PLX chip for that? I read the mainboard manual and it looks to support bifurcation. 4x4x4x4. Perhaps one of you know? I know this board wasn’t entirely recommended, but it seem like for a home lab? I think it might be the solution.
I will start with some old spinning rust and Sata SSDs cause that is what I got laying about (enough of same sizes). I will try out some Nvme I have got laying around too and a dummy card to see if bifrucation is supported without the UEFI/BIOS doing some odd raid config thing. That pool will mainly be iscsi block for steam. The manual is a little confusing re Nvme.
I am running an old supermicro board x10 series I think? E3 Xeon. It is running fine. I just have to get the weight, size, and power consumption down. Easy to load on a dolly, if it even ends up weighing that much after getting rid of most of the WD Reds. 32 gig of ECC DDR3 while my new mainboard will need DDR4 so I had to buy a single stick. Again hope to keep power consumption down.
I have liked what 45drives is doing for a long time but way to large for my needs. Soo I splurged.
The smaller form factor really appealed to me and some bling too! (custom front panel logo). I am still using PC cases from the 90s folks! I rebuild and rebuild even in cases that cut my hands up , so a case like this? I think it will be well worth. It will be a welcome change! My servers have always gone in better cases than my PC builds. They are all “sleeper” PCs. lol ATX thank goodness has been ATX 4ever!
Well be kind. I would love suggestions? Cost is not a huge concern for the system but 1200 - 1400 USD for an SM board was a bit much or I could find what I already have for a decent price but it is micro-ATX.
I have always wanted to do an Mini-ITX build so this is a chance to give that a go. Dare I say it? The case will be sexy AND functional. It does look to have great airflow if I manage my cables well. I hope the cooler has enough room? It i not very tall…
Thank you for coming to my Ted Talk!
Now… How do you set up TrueNAS permissions again??? lol I am already starting to loose sleep over them. :slight_smile:
I actually did a very similar build in an HL8 chassis earlier this year. It’s also running TrueNAS as my offsite NAS backup. :slight_smile:
I’m a big fan of the AsRock Rack X570D4I-2T motherboard. It’s worked really well for me with 10G networking, four slots of ECC memory support, and integrated BMC provides management features plus onboard VGA graphics. I can also confirm the 4x4x4x4 option is available in the latest 2.5 BIOS in my setup.
One note for you, you’ll need to remove the CPU back plate from the motherboard in order to install the fan you bought. I documented doing that midway through the comments. It’s easily doable with a little bit of patience.
I’m looking forward to your findings with 5650GE ECC support. You’ll see my in build post from above that there was also a lot of speculation on which CPU’s would or would not support ECC. Since it’s a PRO CPU, I think it will support ECC as well as integrated Radeon graphics.
If your TrueNAS is doing all that currently, that’s fine, but you might want to look at running TrueNAS under Proxmox if you are heavily into containers and VMs. Not something I do personally, but I do see that VM management in TrueNAS isn’t very robust, and to move forward with containers in 25.04, they have taken some steps back with VMs. You might want to stay on 24.10 or wait to upgrade until 25.10.
From that description, it doesn’t sound like you need a lot in the way of backup, but what are you doing for backup? You must have some important personal documents, photos you don’t want to lose, etc. Will you still have a fixed location for a buddy server? use a cloud service? Use an external SSD like a Samsung T7 or Sandisk extreme portable?
What is your estimate of your usable-space need? You’ll want to increase that by 20% and then adjust for any RAID. What RAID level do you think you’ll use? You probably don’t need caching in an all-SSD system. Since ZFS doesn’t support mixed capacity drives like Synology SHR or UnRaid, you are probably best to have 4x of the same capacity drives in the drive bays, and 4x of the same capacity NVMes on the PCIe card.
I don’t have all of those calculations at hand right at the moment but yes, I have my storage needs, pools, raid Z levels all figured out. IF I am able to do what I wish to with the HW. At the moment there is some doubts in the TrueNAS forum that the Mobo and CPU combo will work the way I had hoped with three main things I will have to test.
ECC Support with APU choice
4x4x4x4 support with APU choice and available PCIe bus lanes
SATA bus lanes supploed by an odd onboard connector that requires some type of breakout cable and onboard NVME might be in conflict with use of that port. Again a bus lane conflict.
I will put it all together and test. Possibly require a new mobo solution and / or APU (CPU) solution.
Thanks for your reply!
Ubiquity has just refreshed the UniFi networking line with new gateways and new switches in their compact product line. Do pay attention to supported applications when picking. The Cloud Gateways can run Protect, Talk, etc. The access points are robust. I have a pair of in-wall access points in a small mid-century ranch.
Happy trails,
Dave
You’ve mentioned the ECC concerns and I just watched this video recently and the presenter’s take is that ZFS without ECC is better than no ZFS.
Interesting video and not too long.
ZFS is going to protect data on disk better than any other file system, assuming you scrub. Where people diverge is how vulnerable or important a flipped bit in RAM is to their data. A flipped bit in RAM isn’t going to end up corrupting the whole ZFS pool like some sort of virus. The ECC question is just; is that level of data integrity verification something that is important for one’s data? If you are running a billion dollar HFT operation from your homelab it probably is, if you are playing Steam games on a system that is off much of the time, it probably isn’t. But that decision is a personal one.
Although ECC and ZFS are separate, for some people ZFS implies “and to end data integrity validation” and for those people ECC is a must to ensure that chain is maintained while data is in RAM.
