I’ll start by saying I don’t think your experience here is atypical, but I wouldn’t necessarily contribute it to the HL8. This is more about the differing software philosophy behind Rocky Linux, Cockpit Project, and HoustonUI. I believe the general expectation from Cockpit (and by extension Houston which are 45Drive written cockpit modules) is that you will install what you need as you need it (samba, nfs, etc.) and avoid unused software on your computer that could pose security risks. I believe some of the cockpit modules check to see if the software is installed and will even give you an error but that doesn’t seem to be the norm in my experience.
Ultimately, what you’re going through is what drove me to choose TrueNAS for my HL15 and HL8 as I was looking for more an appliance experience that “just works”. I didn’t really want even need all the freedom I’d get with full fledged Linux Operating system like Rocky with a web front end via Cockpit/HoustonUI.
Hi Ryan, thanks for the comment. I agree with your sentiment to a point. I would expect, however, that if Houston UI has a SMB file sharing tab in the UI by default, that SMB functionality is installed by default. Maybe I read too much into the product as a complete NAS solution (especially SMB) out of the box - if so, that’s my mistake. I don’t mind installing extra features if needed but it seems that NAS features should be installed (if not enabled) by default. I’d like a comment by the HL8 product manager to set this straight about product expectations. Are these bugs (or oversights) on the release of the HL8/Houston UI or an error in my expectations for the product.
I can’t say these would be the choices I would make either in this situation but reasonable minds can certainly differ. I may also afford 45HomeLab a little too much leniency. I work in product management in the software/online space, and I understand all too well that there is a constant barrage of trade offs, time, and cost factors going into even the smallest decisions. 45HomeLab also comes from the enterprise space where this type of stuff is looked at very differently. I like that they are trying to serve the HomeLab space by leveraging their enterprise gear and expertise. It’s just a weird niche market that sits in between the enterprise and consumer business models. I’m confident they’ll figure out the sweet spot at some point where we get the best of both worlds. It’ll just take a little bit of time.
Do you mind sending some of the logs that are in
/var/log/cockpit_zfs_getdisks.log
and
/var/log/cockpit_zfs_getpools.log
to see if there is some issue there? You could also check the devtools console using F12 to see if you have any errors loading data.
Hi Hutch, well, things are worse after updating to the new cockpit-zfs. After installing it, the Houston-Dbus service fails to start (even tried rebooting).
Log for the Houston dbus service follows:
9:27 AM
Failed to start Houston D-Bus Service for Cockpit.
systemd
9:27 AM
houston-dbus.service: Failed with result ‘exit-code’.
systemd
9:27 AM
houston-dbus.service: Start request repeated too quickly.
systemd
9:27 AM
Stopped Houston D-Bus Service for Cockpit.
systemd
9:27 AM
houston-dbus.service: Scheduled restart job, restart counter is at 5.
systemd
9:27 AM
houston-dbus.service: Service RestartSec=100ms expired, scheduling restart.
systemd
9:27 AM
systemd
9:27 AM
houston-dbus.service: Main process exited, code=exited, status=1/FAILURE
Same problem here. New HL15 fully burned in. I have 2 services that are failing to start. /etc/systemd/system/houston-dbus.service failed to start. Same error messages that CPN is getting. So I won’t post the Service log.
ALSO:
/usr/lib/systemd/system/tuned.service failed to start
8:03 PM
Failed to start Dynamic System Tuning Daemon.
systemd
8:03 PM
tuned.service: Failed with result ‘exit-code’.
systemd
8:03 PM
tuned.service: Main process exited, code=exited, status=1/FAILURE
systemd
8:03 PM
AttributeError: ‘Daemon’ object has no attribute ‘_profile’
tuned
8:03 PM
return self._profile is not None
tuned
8:03 PM
File “/usr/lib/python3.6/site-packages/tuned/daemon/daemon.py”, line 322, in is_enabled
tuned
8:03 PM
elif not self._daemon.is_enabled():
tuned
8:03 PM
File “/usr/lib/python3.6/site-packages/tuned/daemon/controller.py”, line 121, in start
tuned
8:03 PM
res = self.start()
tuned
8:03 PM
File “/usr/lib/python3.6/site-packages/tuned/daemon/controller.py”, line 56, in run
tuned
8:03 PM
result = self._controller.run()
tuned
8:03 PM
File “/usr/lib/python3.6/site-packages/tuned/daemon/application.py”, line 215, in run
tuned
8:03 PM
app.run(args.daemon)
tuned
8:03 PM
File “/usr/sbin/tuned”, line 98, in
tuned
8:03 PM
Traceback (most recent call last):
tuned
8:03 PM
Starting Dynamic System Tuning Daemon…
systemd
Similar issue with zfs pools with new HL15 fully burned. The disk slots were aliased on mine 1-1 → sda. etc. However after creating pool, it will not show up in Houston. Shows up fine on command line with zpool list though.
I just received a fully burned in HL8 as well and are receiving service failure for /etc/systemd/system/houston-dbus.service. Was anyone able to get this resolved ?
Hi All, sorry for the delayed response to this issue but we do have a fix. This fix will work for both the dbus service issue and for drives not properly displaying in the disks tool.
Please switchback to cockpit-zfs as that is our new ZFS module.
dnf remove cockpit-zfs-manager
dnf install cockpit-zfs
Then check which version of python is running with this command:
alternatives --display python3
This will show installed/active versions one should be running and the other will be “current best” if these don’t match run the command: alternatives –auto python3
Refresh cockpit-zfs and start/enable the dbus service. Please reply here if this doesn’t work.
