Hi, I have an adjustable 15U wallmount rack, but at the max, it is not that deep. Just wondering if the HL15 would fit in it when the power cord is plugged in. Can someone with one can measure from the rack ears (inside) to the back with the power cable please ?
Thank you !
Case looks to be about 20in (50cm) front to back.
You would need about another 2in (5cm) clearance for the power cable and ethernet cables to stick out.
However, if you get the rails, those seem to have a min depth of 27in (~68cm)
if you buy a right angle power plug you might be able to fit it in smaller than the 22in
edit: similar post about this here: Will it fit my rack? Trying to figure out before purchases
Thank you for the reply. I’ll check if it will fit.
