HL8 (Fully Built & Burned In) ECC?
I’m looking to get a dedicated NAS system and have heard great things about 45Drives. Im thinking about getting the HL8 - Fully Built & Burned In but would like to confirm some confusion in the specs.
I have seen a few posts somewhat around this topic that indicate ECC might not be supported but there was also a reply from Vikram-45HomeLab indicating this might be supported in a new option? I’m wondering what the current status of this is at in 2026? Should I send a quote request for the pro version from here?
Thank you in advance for your time!
You must be referring to this post :backhand_index_pointing_down:
I’m guessing something didn’t pan out as it’s still not an option. 45HomeLab and I often have different expectations around “soon”, but this is getting up there at six months and counting. :confounded_face:
You can always email info@45homelab.com or call (866) 471-8188 to inquire about a full build with ECC. From what I understand, the Pro8 is geared towards MSP’s. It may have additional costs or markup baked into the price as a result.
Yeah thats the one! (I couldn’t post 2 links since I’m new :sweat_smile:)
I will give that email a shot and report back with what I hear back. I might be willing to stomach some markup. I started down the rabbit hole of looking into a DIY build and don’t have the time to go through my due diligence for the Hardware and the TrueNAS software. I was thinking this HL8 should be able to handle all of my needs in one, but if I’m paying for a pre-built NAS I’d prefer it has ECC.
Thanks for the quick reply!
Definitely let us know what you hear back. I did my own custom HL8 build a while back as I wanted both ECC and BMC features. It’s my offsite TrueNAS Backup and runs the latest version of TrueNAS just fine. I was hoping the 45HomeLab team would consider shamelessly copying the build but doesn’t look like it. You could use it as a starting point though. It’s the “Pro Max” configuration that I went with. Pictures and more details are in the replies.
Also, good luck on the RAM pricing front. I’ve heard DDR4 is less impacted, but I imagine it’s a lot higher than it was….
I got a response:
I know we said we would add that option to our store; however, this is not
an option we would like to go forward with as of now.
However, I can create a customized quote for you if you want to buy the pro
variant of the HL8.
I’m going to see what a pro HL8 will cost, but if its a significant mark up I might end up looking at your custom build :saluting_face:
@dvd Checking in - did you end up going with a PRO8 or a different route?
Hey, I’m deciding to hold off for the time being and just keep using my desktop PC as my NAS until I feel I need to do an upgrade. I will probably end up going with one of the HL15 variants when I decide to pull the trigger, unless there is another official option available with ECC before then :sweat_smile:
