Well, store is live although no email and not clear how to apply preorder code quite yet… getting closer!
When I enter my discount code in, it tells me it is invalid.
@seanseagren I also have the e-mail telling me that the store is live but I do not have my e-mail with an account to sign up with. I am hoping I will see it soon!
Same issue. Hopefully someone on here can share the site.
the 45homelab.com page just updated for me with an actual store.
I created an account, but cart is definitely not ready for prime time quite yet. Seems to be locked to a particular product… guess I just have to be a little patient for the next email.
I am trying to figure out if I should be making an account using my pre-order e-mail or if I should be waiting for the mentioned link.
That is what I did, and got the activation email. But would probably wait, hoping when things settle and the second email arrives all will be well…
Store and cart seems to need some help. Unsure about booking the order right now. Can’t change the product options, and when I do by starting over, the product doesn’t update. ![]()
The order page seems to be missing some options too. They said there are supposed to be SSD mounts that can hold up to 10 SSDs inside the motherboard space, like they have on their 45 drives models, but it is not one of the options on the order page.
Has this been made clear yet? I have the “the store is live” email but not the “create an account” email. Can I just move ahead and create the account on the site or will that mess up some linkage and cause more problems?
I created an account and placed order with discount code from original reservation e-mail.
My order has been placed!
Order placed as well… Can’t wait
Hi. I created the store acount, configured the order, applied the discount from original email. everything was fine. however i never checked out beacasue i decided to change the configuration. Now the discount code does not work. it says that it has been used.
I had this issue too, and I’ve dropped them an email!
can’t pick a Package, so I can’t order ![]()
Did you make your account with the same e-mail that you used to submit your pre-order?
Yes, I could login 5-6 hours ago. I’m in Sweden. So store went live 1am. Then I couldn’t get pass the check out process as many others. I tried for an hour or so. Finally I gave up and went to sleep. So when I woke up, naturally I tried again. But now I can even see any options or login. When I hit login button nothing happens. And no options shows up at all when trying to get HL15 to my cart.
Can anyone see the options in store right now?
