I ordered the HL15 case and it should arrive next month. I’m very excited about it! I’m considering purchasing an AMD RX 7900 XTX and using this case for my main gaming and workstation setup. Does anyone know if the RX 7900 XTX will fit in the HL15?
I see 287mm as the length of that GPU. The simple answer is no, the compartment max is about 267mm.
The longer answer is: At a minimum you would need to remove one of the fans for it to fit, and even then you would be at build tolerances to determine if it would fit or not. You’d have a bit of a puzzle in that every time you want to remove the GPU, you’d need to remove the fan wall first, and fit it snugly in place after doing the work. You’d also need to consider if the one front fan would provide sufficient cooling to the PCIe area with the second fan removed. It probably won’t be a quiet build as that fan would probably need to run faster than the others.
If you are comfortable removing a fan you may get it to fit with a mm or two to spare. I wouldn’t purchase it without a return option, though.
