3 of my disks got a Faulted error, I’m going to try replacing the cables to see if that makes things better.
If you have the cables you could measure them. Probably 75 cm, maybe 60 cm.
Not sure that would be my first troubleshooting move.
IIRC i measured 2x cables at .7m and 2x at .6m.
I didn’t write this down, just recall noticing the difference and measuring while I was in there.
Different length might work depending on your setup.
Just in case… I was having issues with multiple drives being fed a single PSU cable to the backplane. I have since improved that and have not seen the issue again. Maybe this is your issue?
