On the 45 Beast there is a choice of front covers - but its not clear what design goes to which choice. I assume the claw mark one is the classic? But again it is not very clear which is which.
In either case these can be on a white background or black background.
For Custom, which has an additional fee, you provide a graphic of your choosing that they will custom print onto a front plate. I think after you place the order they will contact you with more info about the acceptable file formats and process and such. My understanding from another post here is that they use this digital printing process from their parent company Protocase;
Thanks for asking and for the answer, I was wondering the exact same thing! The photo changes when you select the different fronts in the configurator are (apparently) misleading
For me the photo changes seem to show standard and classic correctly, but not always the color. I think Black/Classic showed the White/Classic, and White/Blank showed the Black/Blank. But it did seem to also get confused if I switched between colors after selecting a front plate. So, yes, a bit confusing if they are relying on that (which I wasn’t aware of due to my screen resolution) to indicate the different fronts.
