Just received HL15 full build and setting it up. Following instruction manual but get no connection on the VGA screen upon power up. Screen works fine on other computer. Any suggestions?
Thanks, Eric
How long have you waited? It often takes 30 seconds or so to show a white Supermicro screen before going through the POST. Are you getting an audible beep after around 30 seconds?
Hi @eric4414,
I just wanted to check in on behalf of 45Drives / HomeLab to see if you managed to get your VGA working?
