If you have opted for the full build ( or use select supermicro X11, H11, B11, CMM, M11, and H12 motherboard) be aware that baseboard management consoles have newly reported vulnerabilities. This will require manual patching. New patches for X11SPH-nCTF are not yet available.
Check your motherboard for specifics. Sometimes there is a jumper that can be set to disable IPMI.
On some Supermicro boards:
In order to disable the IPMI, please login the IPMI site and select Configuration → LAN Select → Enable → Dedicated LAN (only) then click SET to save it. After that, you can un-plug the network cable at Dedicate LAN Port. That’s way, IPMI will be disable to access.
basically login to the interface and set it to local only, save it and pull the cable.
