This week I’m building a 2nd and 3rd HL15 Homelab system. It’s a bit of an insane build putting a 64-Core AMD Epyc in each as well as a Quadro RTX 5000.
The primary goal is to use these as cloud application development machines that specialize in image processing. Running S3 compatible object storage locally was a must due to latency of network access to S3 itself, it made more sense to keep the data locally.
However I noticed after ordering the GPU that I didn’t carefully check the GPU size limitations for length. A day before the GPUs arrived I was in a bit of a panic. The Quadro RTX 5000 is 10.5” in length, and that is before you attach the rear PCI-E 8pin and 6pin power connectors. This on paper wasn’t going to work.
Well luck would have it there’s a gap between the fans. It turns out you can fit a Quadro RTX 5000 in the first PCI slots of the case. The power connectors fit back in between the fans. It was a little finicky to install, needing to remove the fan assembly and finesse the install order, but alas it fits perfectly and the power cables even have a nice channel to run in above each fan in the gap.
Thought I’d share for those looking to push the boundary’s of GPU size.
