Proxmox / Ceph / K8S
Good morning all…
thinking this is probably the better place to ask this.
I have 3 Topton mini PC’s, running as a Proxmox cluster, with Ceph enabled, with a cephpool and cephfs configured.
I have 6 VM’s, K8s_master 1,2,3 and Worker 1,2 and 3.
I want to configure the K8S environment to use my external Ceph cluster for persistent storage…
All the videos and doc links I’m finding skim over things,
My cluster was build using the Kubespray stack.
Can anyone help with a good how to, that knows this stack or can help me…
working from basic k8s cluster deployed, no ceph add on’s…
G
I believe you need Rook to connect Ceph with K8S, but I have never seen a good how to for it. All the good how to’s that I have run across seem to focus on Longhorn instead, which I don’t believe is compatible with Ceph. Jim’s Garage Youtube Channel has great K8S and Longhorn videos if that helps.
ye, finding the same… keep on digging…
G
