Alright, hope I am missing something obvious… but is there a trick to getting the case cover off?
Loosened the captive thumb screws and I can slide the top back but can’t pull it up. Took a couple of times to get it back all the way on what appear to be studs in the top back, one side is a little lose but still can’t get it off.
The included QR code for the manual is nice but nothing in there either…
Hmmm, so mine slid right back as did yours. The top cover took a little wiggling to get past those studs in the back (had to kind of tilt the top cover to one side as I did so) but it did come right off.
Toss up a pic if you don’t mind regarding the PSU and I can try and get the same angle if it helps compare and contrast!
Got it- thanks! Definitely takes a little more wiggling but once I knew the path it was easier. Real easy once you get to the right point on the studs, hoping that it’s a matter of getting the right feel for the sweet spot.
Always is. I’ve taken the front panel off 14th and 15th Gen Dells probably about a hundred or so times in the last 3 months alone for some troubleshooting at work. I still fight with it each time.
I see you with your 15x 2.5" adapters… I know what sorcery you’re planning! The orange looks GREAT! Did you print them or order with your HL15? I haven’t gotten around to printing mine, but I may now want to switch up the colors!
Ah, I see what you mean here. This could just be due to how little material is really there when there’s no PSU. Similar to how a PC case side panel gets kinda wobbly when it’s off the case.
I think you’re right that once the PSU is installed it will be a non-issue. If we’re both wrong, well, I have plenty of faith that support will take care of you!
Excellent choice! In the future if you need more, just a note if you’ve not heard. Intel sold their SSD line to SK Hynix who will now be manufacturing them under the Solidigm brand. Just in case you need more/replacements down the line.
I have some S4510’s and S4610’s that have been running in Production for nearly 5 years 24x7!
The ball has been rolling for a bit now, but I think we’re finally starting to see it trickle down into homelab as the older stuff dries up. Though my last few ESXi hosts ordered at work still had Intels I believe.
