Slot 1-4 in my HL15 won’t spin up any disk connected to it. The same disks work in other slots. Drives also slide in a without almost no effort compared to the other slots.
What now? I guess it’s broken and can’t be fixed by me so I’ll e-mail support as well.
@Fossil, Is this a full-build system? if so could you swap the 2 HBA cables on the motherboard? this would reverse slots 1-4 and 5-8 but would allow us to see if its an issue with something in the cable/backplane versus something to do with the motherboard or controller.
If you do not have a full build I may suggest the same troubleshooting but with whatever HBA card you used.
