Hello!
Retired IT but with no linux background here, so it’s very possible I’m missing something obvious.
I just received a new X15 and added in a second nvme in the nearest m.2 slot, and put in a series of ~5-10 year old drives in the bays (mostly 500GB; my goal is to learn and understand how it works before I sell a kidney to buy some big drives).
It boots and logs in fine, but it doesn’t see either the second nvme or the data drives. In the GUI at the bottom it just says
45Drives Disks - Unable to proceed
This module is designed to work with 45Drives servers which feature dedicated storage bays.
Consult any notifications for potential fixes.
If you are still experiencing issues, contact 45Drives Support or let us know by submitting an issue on our github.
Additionally, for a few seconds when loading the Main page of the GUI this pops up next to the above message and disappears:
“ok”: false,
“exitCode”: 1,
“output”: [
“Missing alias file: /etc/vdev_id.conf”
I dug as far as I could (not far), and am hoping all of this is because I have very little idea what I’m doing. In the meantime as part of random troubleshooting I took out the nvme and half the drives.
In case these observations help:
- I see the broadcom controller has two blinking green lights, one blinking faster than the other
-lsblk -d -o NAME,SIZE,MODEL,TRAN returns the initial nvme, 4 virtual hard disks, and 4 virtual cdroms
-lspci -nn | grep -Ei ‘SAS|SCSI|RAID|NVMe|Non-Volatile|Broadcom|LSI’ retuns only the kingston nvme
I did put a ticket in to support but given the holiday week they might not have the time to get to me right away. I wanted to see if anyone out there could be the one to point out the simple tests/fixes I could look into. It’s been about a decade since I built my own PC so I am beyond rusty in this entire area, but excited to get this up and running.
Thank you and stay safe!
It seems like the system isn’t seeing the LSI 9400-16i HBA, although you see blinking lights. With the system off, I’d reseat the HBA and double check the SAS cables are seated in the connectors firmly.
Leave the second NVMe out for now, boot with one known-good SATA drive, and run lspci -nnk (without any filter). You should expect to see an entry for a Broadcom/LSI SAS3416, PCI ID 1000:00ac
If the HBA is absent, you may have a defective HBA or PCIE slot.
If the HBA is present, check whether mpt3sas is listed as the driver in use.
I guess another thing to confirm is is the backplane actually getting power? Did the drives you put in it spin up?
Good suggestion!
I had visually checked that out and pressed down on it, but now I’ve fully pulled it out, removed/reseated each of the four connecters and reseated the card in the slot, but on bootup everything still looks the same. The command you gave me to try didn’t result in anything labeled Broadcom or LSI - though please tell me if I am just not reading it correctly:
00:00.0 Host bridge [0600]: Intel Corporation Raptor Lake-S 8+12 - Host Bridge/DRAM Controller [8086:a740] (rev 01)
DeviceName: Onboard - Other
Subsystem: Gigabyte Technology Co., Ltd Device [1458:1000]
Kernel modules: ie31200_edac
00:02.0 VGA compatible controller [0300]: Intel Corporation Raptor Lake-S GT1 [UHD Graphics 770] [8086:a780] (rev 04)
DeviceName: Onboard - Video
Kernel driver in use: i915
Kernel modules: i915, xe
00:04.0 Signal processing controller [1180]: Intel Corporation Raptor Lake Dynamic Platform and Thermal Framework Processor Participant [8086:a71d] (rev 01)
Kernel driver in use: proc_thermal_pci
Kernel modules: processor_thermal_device_pci
00:06.0 PCI bridge [0604]: Intel Corporation Raptor Lake PCI Express 4.0 Graphics Port [8086:a74d] (rev 01)
Kernel driver in use: pcieport
Kernel modules: shpchp
00:08.0 System peripheral [0880]: Intel Corporation GNA Scoring Accelerator module [8086:a74f] (rev 01)
00:0a.0 Signal processing controller [1180]: Intel Corporation Raptor Lake Crashlog and Telemetry [8086:a77d] (rev 01)
00:14.0 USB controller [0c03]: Intel Corporation 600 Series Chipset Family USB 3.2 Gen 2x2 (20Gbs) XHCI Host Controller [8086:7ae0] (rev 11)
Kernel driver in use: xhci_hcd
Kernel modules: xhci_pci
00:14.2 RAM memory [0500]: Intel Corporation 600 Series Chipset Family Shared SRAM [8086:7aa7] (rev 11)
00:15.0 Serial bus controller [0c80]: Intel Corporation 600 Series Chipset Family I2C Controller #0 [8086:7acc] (rev 11)
Kernel driver in use: intel-lpss
Kernel modules: intel_lpss_pci
00:16.0 Communication controller [0780]: Intel Corporation 600 Series Chipset Family CSME HECI #1 [8086:7ae8] (rev 11)
Kernel driver in use: mei_me
Kernel modules: mei_me
00:17.0 SATA controller [0106]: Intel Corporation 600 Series Chipset Family SATA Controller (AHCI) [8086:7ae2] (rev 11)
DeviceName: Onboard - SATA
Kernel driver in use: ahci
Kernel modules: ahci
00:1c.0 PCI bridge [0604]: Intel Corporation 600 Series Chipset Family PCIe Root Port #6 [8086:7abd] (rev 11)
00:1c.6 PCI bridge [0604]: Intel Corporation 600 Series Chipset Family PCIe Root Port #7 [8086:7abe] (rev 11)
00:1d.0 PCI bridge [0604]: Intel Corporation 600 Series Chipset Family PCIe Root Port #9 [8086:7ab0] (rev 11)
00:1f.0 ISA bridge [0601]: Intel Corporation W680 Chipset eSPI Controller [8086:7a88] (rev 11)
00:1f.3 Audio device [0403]: Intel Corporation 600 Series Chipset Family HD Audio [8086:7ad0] (rev 11)
DeviceName: Onboard - Sound
Subsystem: Gigabyte Technology Co., Ltd Device [1458:fa1d]
Kernel modules: snd_hda_intel
00:1f.4 SMBus [0c05]: Intel Corporation 600 Series Chipset Family SMBus [8086:7aa3] (rev 11)
Kernel driver in use: i801_smbus
Kernel modules: i2c_i801
00:1f.5 Serial bus controller [0c80]: Intel Corporation 600 Series Chipset Family SPI (flash) Controller [8086:7aa4] (rev 11)
01:00.0 Non-Volatile memory controller [0108]: Kingston Technology Company, Inc. NV3 NVMe SSD [SM2268XT2] (DRAM-less) [2646:5028] (rev 03)
Subsystem: Kingston Technology Company, Inc. NV3 NVMe SSD [SM2268XT2] (DRAM-less) [2646:5028]
Kernel driver in use: nvme
Kernel modules: nvme
02:00.0 Ethernet controller [0200]: Intel Corporation Ethernet Controller I225-V [8086:15f3] (rev 03)
Kernel driver in use: igc
Kernel modules: igc
03:00.0 PCI bridge [0604]: ASPEED Technology, Inc. AST1150 PCI-to-PCI Bridge [1a03:1150] (rev 06)
Subsystem: ASPEED Technology, Inc. AST1150 PCI-to-PCI Bridge [1a03:1150]
04:00.0 VGA compatible controller [0300]: ASPEED Technology, Inc. ASPEED Graphics Family [1a03:2000] (rev 52)
Kernel driver in use: ast
Kernel modules: ast
05:00.0 Ethernet controller [0200]: Intel Corporation Ethernet Controller X550 [8086:1563] (rev 01)
Subsystem: Intel Corporation Ethernet Converged Network Adapter X550-T2 [8086:0001]
Kernel driver in use: ixgbe
Kernel modules: ixgbe
05:00.1 Ethernet controller [0200]: Intel Corporation Ethernet Controller X550 [8086:1563] (rev 01)
Thanks for helping out!
The HBA should appear on that list so that is what you need to fix first. I’m not sure if it is a motherboard issue or an HBA issue or something else. I don’t have an X15. Does it come with the HBA in Slot 6 (the one closest to the CPU) or slot 3? You can try swapping which slot it is in with the power off to try to determine if the issue is the HBA or the motherboard. If you have some other known working PCIe card around you could try putting that in each slot and running lspci to see if it is detected to try to determine if the slot is a problem.
If I’m reading the motherboard manual right, the two slots run a either x16/x0 or x8/x8, but I don’t think that’s a detail needed for your case; You aren’t trying to use both slots right now, right?
@DogHeaven, you can also reach out to info@45homelab.com to have one of our support members assist with the troubleshooting.
Thank you! Moving the card to the other slot worked! You’re helping knock the rust off the old gears and get me to start digging through stuff myself. I was not a hardware tech so it’s a steep learning curve already, and my “I’m gonna break it!” paranoia needs some curbing.
To answer your other question, the other pcie slot wasn’t in use, just a network card in the final slot (an x4? I’ll check the manual myself). I didn’t feel the drives spinning (is that how I’d know?).
Sadly I still can’t get the nvme to show up, but now I’ll first see if the one I’m trying isn’t compatible for whatever reason (if that’s a thing). Also if there’s a non-broken reason why the second pcie slot wouldn’t work.
@Hutch-45Drives Thanks! I have been emailing in hopefully a non-annoying way and 45drives is very responsive. I guess I could be all torches and pitchforks but I’ve been on that side of things and it just isn’t productive. (Also it’d make it embarrassing if I’m the one doing something wrong)
I don’t think you’re doing anything wrong. There are actually lights on the backplane (I am told) but you can’t see them without disassembling the chassis. Nonetheless that won’t cause the HBA not to show up. I wouldn’t worry about backplane power as an issue unless you get lspci to show the HBA but drives are still not showing up to the system.
If the HBA isn’t working in either slot it sounds like you got a bad HBA. Whether that requires an RMA, or could be fixed with a firmware reflash I’m not sure.
