Hi everyone,
I’m using a 45Homelab X15 server with the Gigabyte MW34-SP0 motherboard, and I’m trying to figure out whether it supports a standard 4-pin internal PC speaker / buzzer.
The manual says the FP1 front panel header supports the speaker, but the speaker pin assignment is not clearly shown in the user manual. I can see the FP1 table for power switch, reset switch, LEDs, chassis intrusion, and related signals, but I can’t find a clear diagram showing which FP1 pins the speaker should connect to.
Has anyone here connected an internal speaker to the MW34-SP0 inside the X15? If so:
Is FP1 definitely the correct header?
Which exact pins are used for the speaker?
Does a standard 4-pin PC speaker connector work on this board?
Any confirmation, photos, or pinout details would be greatly appreciated.
Thanks!
