Molex power midplate
I have a Seasonic prime TX-1000
  • I assume it’s okay to use to power the midplate?
  • I have two cables in the box, one with two molex’s and one with 3 molex’s. I assume it’s okay if I use two molex connectors from each cable on the midplate?
That will be fine. It’s not concise, but here’s a thread with some supporting info;
Basically, the only time someone might see an issue is if they were a) using a 4-molex cable into a single PSU SATA/PATA port or b) not using all four molex connectors on the midplate. So, spreading the load across the four molexes and two SATA connectors on the PSU, you’re fine.
