I see the full build has a molex connection board. Is this your design for connecting power to all the drives in one place? Or is intended for cable management? I’m asking since I’ve seen other vendors not use this method.
Is the molex board compatible with older POD backplanes? I have a 45Drives v4.0 Pod, and would love to upgrade to a more efficient power supply. Right now I have your 45Drives’ version of the Zippy PSL-6850M.
Unfortunately, that will not work. The older POD systems do not have backplanes. They are our direct wire design so there is no PCB for the drives. Instead each SATA connection is plugged into the HBA card. Also, the older POD systems would be using a custom power harness which is specially made for the PSU that you have.
There is no way to upgrade, unfortunately. Even our new PSUs have the large Molex connectors, and they are not compatible.
That’s too bad. Would you be willing to share the pinout of the old custom connectors, so that I can potentially design a board to interface with them?
Do you think that 45Drives thought that every bit of media that has been released about the HL15 was going to be analyzed like a forensics lab by the community? Everyone is bleeding with excitement!
