Mix SAS and SATA on HL15 Backplane?
I am getting ready to buy a HL15, I have a 9305-16i waiting to be used and plan to migrate my current proxmox homelab over to the HL15. I run Truenas virutalized via a passed through h310 HBA currenlty.
Anyways… as part of this migration, I plan to upgrade my ZFS array from the current 10x4tb 5400 WD Reds to, likely, 6 or 7 14 TB Mach2 SAS drives, but I would also like to use SSD’s for a metadata special device in ZFS. I have a few 256 SSD’s laying around, and I would like to use 3 of them in a 3 way mirror for this task, but they are SATA…
Can I use SATA and SAS drives, through the HL15 backplane and through a single HBA, assuming they drives are in different arrays?
If not, I suppose I could always pass through the SATA controller on the motherboard to truenas and run them off the mobo’s SATA ports, but, ideally I would like to use the drive bays in the front since “thats what I am paying for with the awesome HL15 case”.
Yes that shouldn’t be a problem.
You’ll need to use the official caddies to mount the SSDs in the 3.5" bays, or one of the other hacks since they’re kinda pricey if you don’t print them yourself.
Ok, sweet. I wasn’t sure if there would be some comparability issues with SAS and SATA running on the same controller and backplane.
I would print the caddies myself, so that should be easy enough.
2 posts were merged into an existing topic: Supermicro IPMI activation
