Continuing the discussion from FAQ for the 45HomeLab HL15:
The FAQ says that there should be options for a SSD drive brackets with 2/4/6/10 capacities, but there is no options on the order page for these brackets. Are they going to be added to the order page?
They have STLs for at least the 6-drive bracket over on Printables —> Printables
It looks pretty trivial to expand to 10 drives if you wanted to DIY instead of waiting to order.
Oh and I’ve just seen spare parts too! Printables
Thanks. At least now there is the option.
I’m unable to login to the store and I am unable to activate. So I can not put in my order
