MCP-290-00058-0N which is an Outer Rail Extendable Length 19.6” to 27" correct?
Hi @gh0stee,
Yes those are the correct measurements.
Perfect thank you,
As for adding these to the store, will these be separate or a new addition rail option while ordering the case? Are they the same cost?
Thanks.
As a follow on to this i just got my HL15, and would love to be able to mount it in my Tripplite 12U UPS Depth network cabinet. At 23in deep the cabinet will fit the HL15 but the posts are only 13.1in apart, does any one have a recommendation on a rail kit that would fit. I was looking at the super micro MCP-290-11903-0N kit but im not sure if it will work with the HL15.
