I selected a completed build in my order. Will manuals for the parts come with it? I’m most interested in (hopefully) being sure the motherboard manual comes with the computer.
Thank you.
Kevin
Thank you.
Kevin
The motherboard manual can be found on Supermicro’s website in PDF format. Here’s the link if you need it: MNL-1949.pdf (supermicro.com)
Thank you. I have downloaded the manual. I was hoping the physical manual would be included, but it sounds like that is not going to be the case.
Again, I appreciate your response.
Kevin
