Introducing the limited edition Red HL15!
Introducing the Limited Edition Red HL15!
This 15-bay unit is built with the same big, strong, fast reliability and performance as our other homelab products and is available for a limited time in this striking red design.
This short-run collection is available in all three options, but if you already have an HL15, you can still grab the red faceplate to celebrate Valentine’s.
Hurry! This opportunity won’t last long!
The red HL15 is only available until February 18.
About the HL15:
The HL15 is a homelab server that has enterprise architecture and strength. It has 15 drive bays to provide you with sufficient storage to build the homelab you envision, while providing enough power to run your other applications.
The HL15 is designed, manufactured and assembled in North America. It is built with steel, screws and without rivets so you can take it apart to modify as you desire.
The HL15 fully supports SATA drives right out of the box. Its drive grid is also compatible with SAS drives, delivering full-speed performance in 7 slots (Slots 1-8 to 1-15). To enable SAS compatibility across the other bays, a SAS expansion card is required.
Select the full build package below to secure your own limited edition red HL15.
I really like the look of this. If I did not not already have the black cases in a rack this would def be a purchase.
I like the red and white faceplate. Keep the faceplate option around after Vday. Has a nice patriotic flair to it. My opinion would be to have it as a regular option with black and white chasis that you already have.
@Vikram-45HomeLab for the separate face orders, may i suggest red rack ears? Prexisting will have black ears, which will give 2 choices also, red (with face) or black (from original face) ears
Hi @ZarZ,
I am happy to say that we have considered that and we made sure that the Limited Edition faceplate comes with red matching rack ears.
Is the whole thing red or just the faceplate, ears, and top?
Hey Everyone,
The limited edition HL4, HL8, & HL15 have red Chassis - which includes the body faceplate and rack ears for the HL15!
Here are some images!
Thanks for the quick reply. I guess there is a blue light somewhere to the right which causes a lot of it to look black or blue. I will be placing an order for a second HL15 here shortly.
That’s looking sharp. I wish I needed one now; I definitely get the red.
Kevin
I see that the deadline was the 18th, but are they all gone? I’d probably order two HL15s…
@Vikram-45HomeLab If the special edition red HL15 is no longer available, can you add the red faceplate as a build option for the HL15, in addition to the white and black?
I’ll likely be ordering two today…
Hi Jamie,
can you send me an email at info@45homelab.com and i will do my best to accommodate your request.
