Hi I really want to order from 45homelab.com but I trying to get a custom order is this passable with the following parts?
- HL15 Beast - Chassis & Backplane (Halloween 2026), Front Plate Option 1
- Data Cable Set A
- The backplane power cables for a Corsair PSU. I will buy the PSU in Norway (Corsair HX1500i) so I need the cables that connect it to the backplane. Are these included in the Chassis & Backplane package, or do I need to add them?
- LSI 9305-24i HBA
- Your custom Unraid with a Lifetime license. How would it be delivered without a full build (for example on a USB drive, or as a license key or a M.2 with it on it)?
- The fan bracket from the HL15 2.0, in case I want to rebuild the layout later to get more space inside the case.
- An extra front plate: HL15 Front Plate - No Graphics (Black)
- If I can’t be ready to order before October 31, would you still be able to honor the Halloween colors?
Thank you for reading ![]()
