I have a supermicro 12 bay server that I installed Rocky Linux 8.10 and Houston UI on to. I want to install ceph but there is no tab on the left side menu of Houston for ceph. I was really looking forward to using their ui. Is this because I am not running 45drives hardware or did I do something wrong?
Hi,
You will need to install cockpit-ceph-deploy from our repo and then refresh the page. Once done the tab will show up.
The 1 main issue you will run into is the aliasing of the drives so you will need to manually alias the drive bays using the dalias tool
I got past it I think. I am stuck on
CEPH Core Deployment: Step 2 - Ansible Playbook - core.yml (/usr/share/ceph-ansible/core.yml)
I get to this point when it stops
TASK [ceph-facts : resolve device link(s)] ****************************************************************************************************************************************************************
Wednesday 24 July 2024 20:44:59 -0400 (0:00:00.030) 0:00:32.174 ********
failed: [ceph001] (item=None) => changed=false
ansible_loop_var: item
cmd:
- readlink
- -f
delta: ‘0:00:00.003173’
end: ‘2024-07-24 20:44:59.863478’
item: null
msg: non-zero return code
rc: 1
start: ‘2024-07-24 20:44:59.860305’
stderr: |-
readlink: missing operand
Try ‘readlink --help’ for more information.
stderr_lines:
stdout: ‘’
stdout_lines:
What do I need to do?
Hi,
It looks like you do not have any disks defined in your /usr/share/ceph-ansible/host_vars/ files so ceph can not make OSDs
