Has anyone successfully configured Samba using the Houston UI on a zfs pool? if so, please share a copy of the configuration. And, if you are connecting from MacOS, the connection string?
Thanks in advance.
Troy
Thanks in advance.
Troy
hi @tmpearsall,
Yes I have been able to get a ZFS pool configured from the houston UI.
Make sure you create and configure filesystem from within ZFS module, Then go to File sharing module and add the shares (testparm -s will list your shares from the command line).
The biggest issue seems to be with user/group permissions, so double check those.
Thanks. Will give that a try in the morning ET.
Have you been able to access the share from a Mac using “Connect to Server” via smb? I think my issue is caused by a misconfigured/non-conformant connection string.
I don’t have my hackintosh VM running.
Did you check this setting under the file sharing section?
connection string should look something like this: (change IP address and share name as needed)
smb://192.168.1.101/share
I was able to connect to the Samba share. Spent a few hours dealing with Samba security. Decided to take the path of least resistance and install TrueNAS Scale. Bummer.
I’m surprised actually that you had more permission issues in Houston than you did in TrueNAS. I’ve always had a hard time wrapping my head around their permissions. Maybe because it was mostly done during the beginning of TN Scale.
I haven’t gotten to permissions in TrueNAS - thanks for the heads up!
The final straw for me was syncing between the Houston UI and smb.conf.
TrueNAS permissions is why I left and went with Houston.
If you’re inclined to try Houston again, I’d be happy to walk through the SMB config with you.
The hangup that I found easy to overlook in the documentation is that you need to go to “Identities” not “User Accounts” to set a samba password for each user to make it work.
10 hours in to using Houston I am very pleased. The WebUI is not as refined as TrueNAS, but everything else is far more straightforward. I felt like TrueNAS took 8 different pages of config to get a samba share going that had opaque and poor access control.
I do not have a Houston supported motherboard or HBA so those specific plugins are inoperative at the moment.
So far I’m thunderously happy with Houston.
With some help from youtube I was able to get the permission (to what I believe is) correct. I do have a HBA motherboard so miss the Houston UI. Considering trying it again. Will keep you posted.
This took me longer than I care to admit to figure out.
It’s not mentioned in the File Sharing documentation but in the “How to Create linux user with identities”
