Hey Everyone!
I’ve been looking into the HL4, I’m curious what size GPU will physically fit?
The plan is to use the HL4 primarily as a NAS, but if I a big enough GPU fits, running AI specific VM’s locally is very tempting.
I have no intention of doing any gaming… at all. That’s what the fun machines are for. ![]()
It’s pretty limited. Single slot, full height, 7.5 inches long. Intel Arc A310 and A380s should fit, but AI usually implies Nvidia. I’m not sure what Nvidia or AMD have in those dimensions; the shorter cards are typically dual slot. Typically AI will want faster GPUs with more GDDR, but i don’t know your exact use case.
Had a feeling it would be limited options.
Not a big deal, I’m looking at Thunderbolt eGPU enclosures to work with another old PC just gathering dust.
