Finally received my HL15 2.0 and looking for some tips & tricks to help optimize 10Gbe networking.
TLDR: I get about 9.45 Gbits/sec from the HL15 to the Mac but only about half the speed when going from Mac to HL15 (4.39 Gbits/sec) and am looking to optimize the setup
This is my setup flow:
Mac Studio M2 Ultra —> TRENDnet 6-Port 10G Switch —> USW Pro XG 24 PoE —> HL15 2.0
Here are the HL15.0 Specs:
Motherboard: ASRock ROMED8-2T
CPU: AMD EPYC 7452
Memory: 256GB
Boot Drive: Kingston NV2 1TB M.2
Add-on Card: Supermicro AOC-SLG3-2M2-O (Qty 2)
NVMe Pool: Samsung 990 Pro 4TB NVMe (Qty 4 - ZFS RaidZ1)
HBA Card: LSI 9400-16i
HDD Pool: Seagate Exos 24TB (Qty 5 - ZFS Raid Z2)
GPU: Nvidia GeForce RTX 4070 Super
Mac Studio Specs:
CPU: M2 Ultra
Memory: 64GB
HDD: 2TB SSD
Test Enviorment:
Hypervisor: ProxMox 8.4.5
Windows VM 100:
OS Windows 11
CPU: 12 Cores
Ram: 32GB
Drivers: VirtIO Drivers Installed
TrueNas VM 101:
OS TrueNas Community 25.04.2
Host Location: ZFS RaidZ1 NVMe Pool (Host OS)
CPU: 12 Cores
Ram: 32GB
Passed Through: LSI 9400-16i
Data vDev: Seagate Exos 24TB (Qty 5 - ZFS Raid Z2)
AmorphousDiskMark (Mac to Windows VM)
Test Specs: 4GiB File - 5 Times Average
Windows VM Hosted on NVMe RaidZ1 Pool
QD8 Sequential Read: 8,944 Mbps
QD8 Sequential Write: 720 Mbps
QD1 Sequential Read: 992 Mbps
QD1 Sequential Write: 719 Mbps
TrueNAS VM Data vDev on HDD ZFS Raid Z2 Pool
QD8 Sequential Read: 9,400 Mbps
QD8 Sequential Write: 2,072 Mbps
QD1 Sequential Read: 3,656 Mbps
QD1 Sequential Write: 2,200 Mbps
iPerf3 30-second TCP test with 4 parallel streams
Windows VM —> Mac Ultra = 9.45 Gbits/sec
Mac Ultra —> Windows VM = 4.39 Gbits/sec
TrueNas VM —> Mac Ultra = 9.41 Gbits/sec
Mac Ultra —> TrueNas VM = 5.47 Gbits/sec
Notes:
- I’ve tried with turning testing with Jumbo Frames on & off and noticed no change in results
- Tomorrow Im going to repeat the test with the Mac Ultra connected directly to the switch just to rule out any issues with the cables or patch panel, however since I do see 9.45 Gbits/sec in some test that leads me to believe its not a cable issue but will test directly to verify.
- Ive also increased the CPU count to 24 and memory to 64GB on the Windows VM with no change in performance, I still get about 9.4 from VM to Mac and around 4.4 from Mac to VM.
- On the Mac, I closed down all other apps to ensure maximum performance, although the M2 Ultra should be more than enough power to handle the task.
- I tried iPerf3 with 1-10 parallel streams and saw no noticable difference, although with fewer than 4 streams I wasnt able to fully saturate the line.
Of course 4.4 Gbps from my Mac to the HL15 is plenty for 99% of scenarios so its not something I’m going to die over but I spent more than I want to admit to the wife and am looking to get and optimal setup & configuration out of this just can’t figure out why its so much slower when sending from the Mac into the VMs, about half the speed and pulling from the VM into the Mac.
Any advise, tips or tricks to try? Or is this just some kind of limitation within MacOS that I need to accept?
