I have dual AOC-SLG3-2M2 riser cards installed in Slot 3 and Slot 5. Bios settings remain default. However, only nvme card in Slot 5 is recognized and shows up with a ‘lsblk” command. Card in Slot 3 is not recognized.
What bios settings/changes?
That’s actually the reverse of what I expected you to say you had an issue with. Slot 5 shares bandwidth with Slot 6, so there is an issue bifurcating Slot 5 as x4x4 when slot 6 is populated. See;
For general guidance about where to find the bifurcation settings, see;
Depending on what else is in your build, a simpler solution might be a 4x NVMe card in Slot 6 if you need 4 NVME.
There are other general posts here on this topic if you search on something like ‘bifurcation’ and read the ones specific to the X11SPH/HL15 V1.
