HL15 Case in White - wanted to shake things up a bit on the colors of the rack
System Build
ASUS WS/Pro x299 Motherboard
192GB of DDR4 RAM
i9/10th -18c/32t
10 - 12TB drives (25+ yrs of Photography - Profressional Wedding, constant Nature Photography)
5 - 14TB drives (All DVD/CD/BluRay conversion for Plex)
1 4TB NVMe PCi mounted - for VM Disks
1 SATA 960GB SSD (TrueNAS Install)
Tried to tighten all cable management - its just OK - not to my usual tidyness
Sits on a shelf in the rack for now
This HL15 will replace everything below it as the migrations happen
Not shown however sitting on top of the rack is an entire SDR array for local P25 trunking for Trunk Recorder along with a full WiFi / SDR Monitor being sourced to Kismet Wireless.
Good Luck with everyone’s builds - thanks for looking.
Some of my Socials for my WiFi WarDriving, Systems Building, Radio Frequency Curious Expeditions:
https://www.busysignal.io/wardriveferris3/
https://www.instagram.com/p/DEJlxT9xv8z/?img_index=1
https://www.qrz.com/db/ke2efx
https://x.com/DustinFinn/status/1873535792662057043/photo/1
