HL15 1.0 to 2.0 Retrofit
I’m curious if I buy the new filter retrofit for my HL15 1.0, and I buy a new faceplate, will the new faceplate include the fan screw holes or would it be like the HL15 2.0 where they are omitted? When buying a faceplate will we have the option to include or exclude the holes based on model, and are they swappable (assuming the filter is installed)?
I like the cleaner look of the HL15 2.0, so my intention would be to eliminate the holes with the filter retrofit.
Thanks!
Hey @schnabel45, if you wanted to reach out to info@45homelab.com, we would be able to get an order put in for the retrofit filter and the HL15 2.0 faceplate.
