Hi the Team,
Here to propose a suggestion design for a HL12 based on the Syno 12 bay form factor,
I currently appreciate the Synology 12 bay form factor,
Its compact and has enough slots for extensions for multiple volumes.
The width allow for 120mm fans with good airflow and silent operation.
Having access to the drive on the front is ergonomic and makes maintenance easy. It has 10 Gbps ports and has all the advantages of the HL8 form factor but with 4 more drive rack space, And it has enough drive to stay compact and avoid bigger box like the HL15.
Problem of Synology is, it has quite an expensive price point, closed source OS and software. No easy setup to install any Operating System on their boxes, They also have old hardware CPU/RAM machines because they dont want their home-user/small company products to compete with their enterprise products. In the end, all their hardware lacks behind even on the enterprise side of things.
On the market unless we go custom; I didn’t find a good 12 rack bay form factor that works. The idea is to setup Proxmox or TrueNas Scale with last gen server hardware in a box that can evolve and be modular, ideally with some M.2-nvme slots on the motherboard and a pci slot for 4x nvme pci extension card or small pci GPU.
The setup would consist in Two 6 SATA or SAS drive backplate, or unified 12 6+6 one if it exists ?
The motherboard could sit above the drive box with a Mini-ITX form factor, since it would not be an embedded/integrated (driveplate + motherboard) design, unless one exists for this purpose (i dont think so).
Powersupply could sit on the side of the drive box, or in the space with the itx box room, either low profile or full size one.
Could be also the Qnap style of spacing but with a 12 slots bay set where drives sit horizontally: Image reference: https://gearopen.com/wp-content/uploads/2021/04/1606323946_1605350-695x695.jpg
So I don’t know if this idea resonate or makes sense for the community of builders around. But it could be a good design that enable modularity, and many use cases in my opinion. That form factor chassis could be adapted with different hardware solutions.
PA.
