Apologies for the dumb question, what is the P4 meant to connect to?
I got 4 standard 7pin SATA connector (P0-P3), and a 8 pin connector (P4)? is this meant for supplying power to the SATA drives?
P4 is called a SAS Sideband connector. It’s optional and is used for monitoring the status of the backplane or RAID controller (not the drives). Maybe someone can give you a more complete explanation, I’ve never used it. But that is what you’d google if you want to read more.
I can’t seem to find any specs on the HL15 backplane at all.
What is it and what cables are on the back of the backplane?
The connectors on the SuperMicro motherboard for the SAS3008 appear to be 8 separate SAS 3.0 ports? Does the motherboard have SFF-8654 connectors?
What connector is being used from there to the backplane?
What connectors are on the backplane?
The SuperMicro Motherboard you use on the build only has a SAS3008 HBA which is on 8 SATA/SAS drives? How do the other 7 drives that go in the chassis get connected?
I was considering using an LSI 9300 16i HBA to connect all 15 drives to on the backplane or splitting them between that and the SAS3008 HBA on the supermicro motherboard and the LSI 9300 16i HBA.
The X11SPH motherboard in the full build has two SFF-8643 ports connected to an onboard LSI 3008 controller supporting 8x SAS3 12Gbps drives and two SFF-8087 ports connected to the C622 chipset supporting 8x SATA 6Gbps drives. The full build uses what they list on the web site as cable set “B”, which is two SFF-8643/SFF-8643 cables and two SFF-8643/SFF-8087 cables, to connect the motherboard to the backplane. The backplane only has 15 drive bays, so one of those 16 lanes goes unused/unavailable.
What that means is that if you are using only SATA drives in a full build, you don’t need any additional HBA. And also that you can mix a combination of SATA and SAS drives up to eight SAS drives without an additional HBA. You only need an HBA expansion card if you plan to run more than eight SAS protocol drives.
What is the interface from the HDDs to the backplane? SFF-8482
What are the types and numbers of power connectors on on the backplane?
I read some threads about wanting to direct connect the drives individually instead of via an HBA backplane. What is the best practice?
Also, what about SATA or SAS drives which have the “Power Disable Feature”
Is there anything to know about how to make sure the drives spin-up if these drive types are used?
The original 45drives pods, i believe, had forward breakout cables to each drive. There is a thread or two here from forum members rebuilding old pods. There isn’t any downside to the backplane that I know of, there is still a direct data path from each drive to the motherboard/HBA. Some backplane designs from server manufacturers use port multiplier designs that multiplex the data from multiple drives over one cable. For example, I have a Supermicro server that has 16 drives running off of just two SFF-8087 connectors. There is, as you would expect, a performance hit with that design when under heavy workload. As I described, the HL15 backplane is not a port multiplier backplane.
If I use a LSI 9500-16i card it only has Two SFF-8654 x8 ports and your backplane has 4x SFF 8643(“Mini SAS HD”) ports.
Note: I will also more than likely use the SUPERMICRO MBD-H12SSL-NT-B ATX Server Motherboard which has no SAS3008 because I am going to use the LSI 9500-16i Gen4 card instead.
Do you provide a cable breakout for this in your build for just HL15 Chassis & Backplane?
I am planning on using the following power supply:
Seasonic Electronics Vertex GX-1200 1200W 80 Plus Gold ATX (Dimensions: 160 mm (L) x 150 mm (W) x 86 mm (H)) - so i will dedicate a single PSU port per the 4 molex connectors on the Backplane.
