Help: Dismal Wizard filled / -- doh
/ is full /home is 2%
The internal disk is about 512 GB and was preinstalled as follows
nvme0n1 259:0 0 465.8G 0 disk
├─nvme0n1p1 259:1 0 600M 0 part /boot/efi
├─nvme0n1p2 259:2 0 2.6G 0 part /boot
└─nvme0n1p3 259:3 0 462.6G 0 part
├─rl-root 253:0 0 147.8G 0 lvm /
├─rl-swap 253:1 0 23.3G 0 lvm [SWAP]
└─rl-home 253:2 0 291.3G 0 lvm /home
I’ve added Podman, Portainer-CE, and several containers that I suspect are in / My ChannelsDVR is in a container but its spool volume for recordings is over in the RaidZ2 pool.
I also tried to setup SyncThing and managed to scatter buckshot in various places. Including /
I think I ran that down.
I’ve been looking around in Disk Daisy (what we call it on MacOS)
/var appears to be pretty chubby with Flatpak library bits
I have a nice 32 TB RaidZ2 pool – can we put /var and /opt there and link them? Will it start?
There’s nothing there I can’t rebuild or abandon. Would I be better off to combine root and home for a hobby system? That would be a reinstall. Do we have a checklist for a recovery installation? At a minimum, it needs the 45drives Repository plus Houston UI. Oh, and ZFS in the hernel? It looks like you have to add it to Rocky Linux 8 or 9.
Any hints or recommendations,
Thanks,
Dave
I found all the cruft. A misdirected co[y put a directory full of music in /
Also, Docker/Podman chews on root for containers and volumes.
I cleaned all that up and machine can breathe again.
I also found the warning that Houston UI is Rocky 8 specific for now.
Dave
