Finished my HL15 build
Finished building my HL15, the only thing missing is a GPU for Plex which I have in storage somewhere but need to go get it still. It’s on the floor in the living room for the next few months as I am waiting for the keys to my new house, there it’ll get rack mounted.
Because it’s on the floor and there’s 2 cats and a dog I put some mesh filter material in front of the intake fans. All 6 fans are Notcua Redux fans spinning at around 500rpm and are super quiet.
I’m using TrueNAS Scale. Put all my containers in a VM because those TrueCharts apps and K8s are overcomplicated for most use cases imho. TrueNAS only runs storage and perhaps Plex (not sure if I will run that in the VM with GPU passthrough etc.).
I had someone 3d print the SSD cage which can be mounted in the back and will probably use that for some more SATA SSDs I have laying around and connect those straight to the motherboard.
Slot 4 of the backplane is broken so no disk in there. I’m talking to 45Drives to get it fixed/replaced.
Storage:
  • 2x 2TB Samsung NVME
  • 2x 1TB Samsung SATA SSD
  • 1x 1TB Samsung SATA SSD (Not shown in pic. Used for downloading, unpacking, repairing)
  • 1x1TB WD Purple (Not shown in pic. Used for running 2 IP cameras)
  • 8x Exos X16 16TB in RAIDZ2 using one of the NVME for SLOG
Hardware:
  • Ryzen 7600 with a Noctua NH-D12L cooler
  • Asus ProArt B650
  • 64GB DDR5 (non ECC)
  • Broadcom 9305-16i HBA
  • Intel X550-T2 Dual 10GE NIC
Idle power consumption is 100W without the GPU.
@Fossil - Looking nice and ready to go.
How did you connect your Noctua redux? They don’t look like they are plugged into the motherboard and I don’t see a fan controller. Are you using PWM?
I have 4 PWM headers on the motherboard for chassis fans. Used two of them with 3 way PWM splitter cables. One of the others runs the 40mm fan which I screwed on the HBA because it would go over 100 degrees C otherwise.
Got one free for maybe an exhaust fan if needed but the drives and CPU are 37 degrees after 48h of continuous writing. The HBA is now 60 degrees.
One downside of this build is the Exos drives. They are bloody loud, even when doing something as simple as streaming a movie via Plex you can hear them clearly which is annoying the hell out of me.
Also annoyed by this; if anyone has ideas, would be much appreciated!
I’m thinking some kind of SSD disks?
Cool build! I also slapped a Noctua NH-U9DX i4 in my build and it was a perfect fit! The printed SSD sleds are cool! I wanted a reason to print them but my bays are filled with HDDs lol.
I have a few Western Digital’s 14TB Red Plus (Part#: WD140EFGX). These drives are quiet, but not as fast as other drives.
Nice. Almost identical to my setup, just one generation newer :slight_smile:
  • Ryzen 5900x
  • ASRock X570D4U-2L2T (with dual Intel X550-AT2 10GE NIC)
  • 128GB DDR4 (ECC)
Which CPU cooler are you using?
I thought about putting 15 Samsung 8TB QVO SSDs in but the cost would be way too much for what I am using it for. Also those SSDs are kinda slow after it used up it’s builtin cache. Maybe in a few years if prices some down and SATA SSD sizes go up.
WD Red Pro’s are quieter but not super quiet and they cost almost double what the Exos costs.
I’m using the Noctua NH-D12L.
@Fossil ,
What did you do with the 2-pin fan headers (black/white wires)? Just tuck them out of the way?
Do they make “caps” to cover those pins (or 3 pin variations) so they don’t end up touching anything or each other?
Just some electrical tape
Love the red on those SSD caddies. Great looking prints/filament!
Shrink tubing. I don’t like using electrical tape for long-term applications. It gets gummy and loses grip. Not a fan of shorting out my PSU because of a quick fix.
Awesome looking build. I am a complete noob to this process and I have never built something with a backplane. How does this connect to the motherboard for data? Do i need to have 15 sata cables connected to the board? Thanks.
Welcome @eechee! A motherboard with 15 or more SATA ports is an option but you’ll most likely one or more SFF 8643 “Mini-SAS-HD” connectors which can communicate four SATA connections on a single cable. The HL15 has four of these connectors on the backplane. Regardless, you will need some combination of SATA and/or SAS connections available either on the motherboard or a PCIe card. Ultimately. the hardware you choose will determine which cables to buy.
45HomeLab offers a number of different cables you can choose from when purchasing. Screenshot below is the current offering as of today.
Thank you. I am likely repurposing an Asus ProArt Z790-CREATOR WIFI with 14900k. I assuming I will need to purchase some sort of a pci card for this purpose.
Looks like that board has 8 onboard SATA ports but you’re correct that you’ll need a PCIE card to fully populate the backplane. You could get an 8 Port SATA or HBA card to make up the difference or look for a 16 port card to handle all the drives. Either way works out just fine with the HL15.
Thanks! I will review some options.
