So it should be connected right? But dnf update, traceroute 8.8.8.8, and ping 1.1.1.1 all timeout unable to connect as does my web browser.
I also tried disabling the firewall under the copilot settings http://localhost:9090 with no success.
I’m really at a loss here, other things are connected via the same switch and work fine and I can access the server via IPMI (reason I used screencaps), so I can’t figure out why it isn’t working, where it has worked before and sometimes flickers into life and dies off…
Thanks Hutch, I currently have eno1 set as activated. Disabling virbr0 using nmtui just seems to cause another one to spawn. How can I tell the machine to not use virbr0? I don’t recall ever setting that to default or even setting it up at all.
I connected via eno2 from the same cable and with similar settings (IP set 1 number off) and it worked! So I’m at a loss why eno1 isn’t working even though it shows an internet connection.
