Traceback (most recent call last):
File "/usr/share/cockpit/45drives-disks/scripts/zfs_info", line 458, in
main()
File "/usr/share/cockpit/45drives-disks/scripts/zfs_info", line 451, in main
get_zpool_status()
File "/usr/share/cockpit/45drives-disks/scripts/zfs_info", line 350, in get_zpool_status
status_output = zpool_status(pool["name"])
File "/usr/share/cockpit/45drives-disks/scripts/zfs_info", line 113, in zpool_status
groupings.append( [("state",match.group(1)) for match in re.finditer(r"^.*state\:\s+(\S+)",zpool_status_result,flags=re.MULTILINE)][0])
IndexError: list index out of range
HI @manthan, Could you provide more information on what you are doing? From what you shared I do not understand what you are trying to do or what you were doing when this occurred
Ah, was this fresh from the pre-install? There were a few packages missing that I brought up to @Hutch-45Drives that were still in the testing repo. With the workshop full of 45Drives/Homelab elves likely busy making all our toys, they hadn’t had time to get a separate repo up for the HL15 and didn’t want to add packages to enterprise (understandably) that could affect 45Drives enterprise chassis.
I haven’t peeked yet, but will later, to see if there is a new repo up. I just ended up moving the testing packages to lower in priority in dnf and managing by hand for a bit. Was probably the best way to get more familiar with a RHEL type system.
Hi All, We are aware of the issue where the 45Drives motherboard and disks tab do not load on a fresh install. The packages are not on our stable repo as @orix bright up.
This should give you the version of tools supporting the HL15. We are working on getting the stable repo updated to support this server (or a separate repo)
