Can't connect to Houstoin web UI 9090 not open
Fresh setup no web ui. ss -tulpn shows:
[45drives@hl15 ~]$ ss -tulpn
Netid State Recv-Q Send-Q Local Address:Port Peer Address:Port Process
udp UNCONN 0 0 192.168.122.1:53 0.0.0.0:*
udp UNCONN 0 0 0.0.0.0%virbr0:67 0.0.0.0:*
udp UNCONN 0 0 0.0.0.0:111 0.0.0.0:*
udp UNCONN 0 0 127.0.0.1:323 0.0.0.0:*
udp UNCONN 0 0 [::]:111 [::]:*
udp UNCONN 0 0 [::1]:323 [::]:*
tcp LISTEN 0 128 0.0.0.0:111 0.0.0.0:*
tcp LISTEN 0 32 192.168.122.1:53 0.0.0.0:*
tcp LISTEN 0 128 0.0.0.0:22 0.0.0.0:*
tcp LISTEN 0 128 [::]:111 [::]:*
tcp LISTEN 0 128 [::]:22 [::]:*
Any ideas? sometimes I miss the obvious int he lab.
SOLVED: With command: systemctl enable --now cockpit.socket
Found help here: KB450470 - Rocky 8 Linux Houston UI Installation - 45Drives Knowledge Base
Paying forward.
We will look into adding this step to the user manual. thank you for bringing this to our attention.
When you are connecting via SSH, the message of day prompt will include what you are reporting as part of the welcome prompt.
if you log in directly then you will not see this information.
