Is there a prize for borking the cockpit interface?
What I think I did: while trying to find a way to install gsmartcontrol, I enabled the 45 drives test repo and did a dnf update. A few hours later, I started with the manual on page 42 for setting up zfs. This is what I get:
The issue is that you updated all packages from our testing repo so the ZFS tab is looking for a newer version of SMB than what is currently installed.
If you look at the version of SMB you have installed there should be an update for it.
When I choose most recent kernel (4.18.0-513) from boot screen, I get the user login graphical prompt. After login, the screen goes black. I can use CTRL+ALT+F2 to get a command line login prompt and that works.
If I drop to a previous kernel (4.18.0-477) at boot, the graphical login works, but I get ZFS fails to load errors (which I assume is because I am not on the latest kernel)
If I were to download rocky 8 ISO, is there a setup script to get me back to the “out-of-box” initial setup?
We do not have a HL15 script for “out of the box” but if you run this script it should get you close. you will manually need to enable the testing repo and download specific tools like the motherboard tab for it to work with the HL15
