First off, my apologies for the long posts, but want to provide some information along with my request for feedback and suggestions.
I am constantly thinking about and or planning the next changes or upgrades to my sudo-production/homelab. I have an idea about what I want to move to in terms of the number of systems and what task(s) they will perform I am not sure what direction/chassis to use.
I plan to run 5 systems as part of a Proxmox VE cluster with at least 2 SSDs for the OS, the ability to run at least 4 Ceph SSD OSDs and enough PCIe slots to cover my networking needs (1 x 1Gb management, 2 x 10Gb Ceph and probably 4 x 1Gb for VM use). On the storage side of things I plan to run 7 systems as part of a Ceph cluster with at least 2 SSDs for the OS, the ability to run at least 8 Ceph SSD OSDs and enough PCIe slots to cover my networking needs (1 x 1Gb management, 2 x 10Gb for Ceph).
I keep going between the Rosewill 4U (12 hot-swap or 15 internal and adding hot-swap cages) chassis, the 45HomeLab HL15 and building my systems out using off-the-shelf components. Or continue using older enterprise equipment but upgrade (my HPE DL380 G5 servers) to newer hardware like a Dell PE R730XD. The options I am considering are boiled down to these main considerations: Upgrade/adaptability, power and heat generation/consumption and initial and long-term sunk cost.
My concerns with the old enterprise equipment are mostly around upgradability, HEAT management and POWER draw as right now my systems are pulling about 200 to 300 watts each and I have 7 of them running 24/7 and I do not see the R730XD setups pulling any less power and will still be quite hot as they are a 2U chassis. This setup is also restricted by its nature and it is not a chassis that can be easily used or upgraded when the hardware inside has reached its end of use, though they are mostly readily available and should be for the time it would take me to purchase the quantity I am planning for.
When It comes to the Rosewill option my concern is about the availability of rails as I already own 2 of these chassis though they are the 15-bay without hot-swap models but I have yet to find rails or a recommendation on rails that are still available and will not have fitment issues with other equipment in my racks. However, they will allow for better management of heat given their larger size and the ability to add larger fans. They also are upgradable and should last through more than a few hardware upgrades and would only be replaced if there was a failure in the front panel, metal fatigue or I needed more drives in a single chassis.
The HL15 is one of my newer considerations as it was as we all know only more recently released to the market and while it seems like a chassis that will last for years, has available rails and holds the most drivers per chassis it is a larger initial cost and I would not be buying all the systems I am planning for at once future availability is not guaranteed.
I would love to get feedback from the community or input on which way I should lean and also what other things I might not have thought about that I should consider. Also, I realize this is a forum for 45HomeLab but I am hoping that this will help steer me in the best direction for me and my future sudo-production/homelab changes and upgrades.
