Hello!
I am looking to buy some IronWolf Pro drives for a great price from Memory Express in Canada. https://www.memoryexpress.com/Products/MX00128832
They are coming straight from the store.
Do I have to use the Drive Checker on them?
Hello!
Not sure I understand the emphasis there.
Of course you do not have to.
Checking SMART data isn’t an intensive operation. It couldn’t hurt The likelihood seems low that ME’s supply chain would have used drives, assuming you are purchasing them from the storefront as new and not used, but it should only take a minute/drive or so to ‘trust, but verify.’
I assume Drive Checker is just a gui over smartctl. Do note that some SMART data isn’t an open standard, but is vendor proprietary and interpretation needs reverse engineered by these SMART utilities. So there is also the chance of “false positives” if the software isn’t decoding the SMART data correctly.
After trying a bunch of different stores and sources, I’ve come to the conclusion that the only way to be sure you’re not getting a refurb, mismarked, returned, or otherwise not factory new drive is to buy direct from the MFG. If it’s a “great price” I’d be willing to bet it falls it to one of the above classifications.
FYI all the drives are now on order. Is there any red flags I should know when I receive them? I trust the company I’m ordering from. I think it would be VERY bad press for said company if people ordering drives from them finds out they are used already.
Even outside of this new drive purchase, you should have a way to monitor and view SMART data for the drives in your NAS. There are different ways to do this depending on your OS. The 45Drives Drive Checker appears to just translate the power-on hours of the drive to four tiers of how old the drive is:
You would expect a new drive to show Green in this app. But really, a healthy drive is more than that. The most robust SMART info decoder is probably Crystal DiskInfo for Windows. It has had the most development behind it. I don’t particularly like Windows, but if you do have a Windows machine around with a free drive bay or USB/SATA adapter, that program’s parsing of the various metrics and thresholds to warn on is probably the best.
On linux, any of the GUI or interprative tools are built on the smartctrl CLI program. It looks from your other posts that you are maybe running UnRAID? On UnRAID and TrueNAS you can install an app called Scrutiny tha will give you a GUI for more of the discrete SMART metrics;
I have had cases, though, where Scrutiny throws false positive warnings because it is missing some models in its database to know how to interpret some of the metrics.
If you are running Linux but not a NAS appliance there is GSmartControl;
Here are five of the metrics that are most indicative of drive health;
Hello!
Thanks for your insight. Yes, unRAID is the system I am running, especially with my new one I’m hoping to order soon.
I will look into Scrutiny. I’m currently using unRAID’s built-in monitor but could always use a second pair of eyes where I can.
Do you happen to have a more up-to-date guide for Scrutiny?
Sorry, I don’t use UnRAID (mainly TrueNAS/Proxmox), but my understanding is that although the dates on the guides might be oldish, the process of installing a community plugin hasn’t changed. Here is the Github;
Here’s what AI tells me:
Q: is Scrutiny still a good app to run on unraid or does it have built in smart monitoring now?
A: Yes, Scrutiny is still considered a very valuable and often essential application to run on Unraid for drive health monitoring.
While Unraid has built-in SMART monitoring, Scrutiny provides several significant advantages that make it a worthwhile addition:
In short, while Unraid’s built-in monitoring is good for basic alerts, Scrutiny is a powerful and proactive tool that can help you catch drive issues before they become critical, giving you more time to back up your data and replace the drive. It’s still a highly recommended application in the Unraid community.
Q: is there an up-to-date install guide?
A: Yes, there are up-to-date install guides for Scrutiny on Unraid, and the process is generally straightforward since it’s a Docker container available through the Unraid Community Applications (CA) plugin.
The key points to an up-to-date installation guide are:
ghcr.io/analogj/scrutiny:master-omnibus (the official image from the developer)lscr.io/linuxserver/scrutiny (a popular image from the trusted LinuxServer.io team)8080 , but you can change it if you have a conflict. This is the port you’ll use to access the Scrutiny web UI./dev/sdX, /dev/nvmeXn1, etc.) to the container. The easiest way to do this is by adding a new “Device” variable for each drive in your array and cache pool. The Host Path and Container Path should be the same (e.g., /dev/sda and /dev/sda).SYS_RAWIO to the container’s capabilities. If you have NVMe drives, you also need to add SYS_ADMIN./opt/scrutiny/influxdb or a similar path, and mapping it to a dedicated folder on your Unraid server (e.g., /mnt/user/appdata/scrutiny/influxdb). This ensures your historical data persists even if you need to recreate the container.A note on finding guides: While guides from a year or two ago might be slightly outdated, the core process of installing a Docker container on Unraid hasn’t changed. The steps for setting up device paths and capabilities are consistent. You can find detailed, visual guides on places like the Unraid forums, Reddit communities, and YouTube. Just search for “Scrutiny Unraid install guide” to find a recent walkthrough that matches your preferred learning style.
Thank you very much for this. I had a feeling it was available under the Community Applications Plugin.
Register the drives as soon as you get them. That’s going to be an instant clue if they’re old/refurb.
How do you do that again? It’s been a while.
