await in loadDisksThenPools
initialLoad @ index.e8b7f461.js:29902
(anonymous) @ index.e8b7f461.js:29964
(anonymous) @ index.e8b7f461.js:3210
callWithErrorHandling @ index.e8b7f461.js:1890
callWithAsyncErrorHandling @ index.e8b7f461.js:1897
hook.__weh.hook.__weh @ index.e8b7f461.js:3195
flushPostFlushCbs @ index.e8b7f461.js:2044
render2 @ index.e8b7f461.js:5553
mount @ index.e8b7f461.js:3936
app2.mount @ index.e8b7f461.js:7861
(anonymous) @ index.e8b7f461.js:31534
index.e8b7f461.js:29141 poolData after JSON load (no root): {name: 'storagepool', status: 'ONLINE', guid: '7222808751287336734', properties: {…}, failMode: 'wait', …}
index.e8b7f461.js:29473 Disk not found in inventory for path: /dev/disk/by-id/wwn-0x5000039b38d12099. ZFS status: ONLINE
handleDiskChild @ index.e8b7f461.js:29473
(anonymous) @ index.e8b7f461.js:29407
parseVDevData @ index.e8b7f461.js:29404
(anonymous) @ index.e8b7f461.js:29031
loadDisksThenPools @ index.e8b7f461.js:29031
index.e8b7f461.js:29530 Mismatch: {child: '/dev/disk/by-id/wwn-0x5000039b38d12048', matched: Array(2), matchedName: 'sdh'}
handleDiskChild @ index.e8b7f461.js:29530
index.e8b7f461.js:29473 Disk not found in inventory for path: /dev/disk/by-id/wwn-0x50014ee20b07fa13. ZFS status: ONLINE
index.e8b7f461.js:29473 Disk not found in inventory for path: /dev/disk/by-id/wwn-0x50014ee20b0a0789. ZFS status: ONLINE
index.e8b7f461.js:29473 Disk not found in inventory for path: /dev/logs. ZFS status: ONLINE
index.e8b7f461.js:29530 Mismatch: {child: '/dev/disk/by-id/nvme-nvme.8086-4356463837323236303…1-494e54454c205353445045434d453031365434-00000001', matched: Array(3), matchedName: 'nvme0n1'}
index.e8b7f461.js:29473 Disk not found in inventory for path: /dev/disk/by-id/nvme-nvme.8086-43564638373232363030303831503642474e2d32-494e54454c205353445045434d453031365434-00000001-part1. ZFS status: ONLINE
index.e8b7f461.js:29330 Disk not found for path: /dev/disk/by-id/nvme-nvme.8086-43564638373232363030303831503642474e2d32-494e54454c205353445045434d453031365434-00000001-part3.
parseVDevData @ index.e8b7f461.js:29330
(anonymous) @ index.e8b7f461.js:29032
loadDisksThenPools @ index.e8b7f461.js:29032
index.e8b7f461.js:29141 poolData after JSON load (no root): {name: 'workpool', status: 'ONLINE', guid: '6446805777961074128', properties: {…}, failMode: 'wait', …}
index.e8b7f461.js:29157 loaded Pools: RefImpl$1 {dep: Dep$1, __v_isRef: true, __v_isShallow: false, _rawValue: Array(4), _value: Proxy(Array)}
index.e8b7f461.js:29287 Selected disk not found Proxy(Object) {name: 'wwn-0x5000cca27ec9da8f', path: '/dev/disk/by-id/wwn-0x5000cca27ec9da8f', guid: '', type: 'N/A', health: 'ONLINE', …}
index.e8b7f461.js:29287 Selected disk not found Proxy(Object) {name: 'nvme-nvme.8086-43564638373232363030303831503642474…54454c205353445045434d453031365434-00000001-part5', path: '/dev/disk/by-id/nvme-nvme.8086-4356463837323236303…54454c205353445045434d453031365434-00000001-part5', guid: '', type: 'N/A', health: 'MISSING', …}
index.e8b7f461.js:29284 Original disk not found in the disks array
(anonymous) @ index.e8b7f461.js:29284
wrappedFn @ index.e8b7f461.js:972
apply$1 @ index.e8b7f461.js:980
forEach @ index.e8b7f461.js:890
(anonymous) @ index.e8b7f461.js:29258
(anonymous) @ index.e8b7f461.js:29257
loadDisksExtraData @ index.e8b7f461.js:29256
loadDisksThenPools @ index.e8b7f461.js:29158
index.e8b7f461.js:29287 Selected disk not found Proxy(Object) {name: 'nvme-nvme.8086-43564638373232363030303831503642474…54454c205353445045434d453031365434-00000001-part6', path: '/dev/disk/by-id/nvme-nvme.8086-4356463837323236303…54454c205353445045434d453031365434-00000001-part6', guid: '', type: 'N/A', health: 'MISSING', …}
index.e8b7f461.js:29287 Selected disk not found Proxy(Object) {name: 'wwn-0x5000c5009441d53b', path: '/dev/disk/by-id/wwn-0x5000c5009441d53b', guid: '', type: 'N/A', health: 'ONLINE', …}
index.e8b7f461.js:29287 Selected disk not found Proxy(Object) {name: 'nvme-nvme.8086-43564638373232363030303831503642474…54454c205353445045434d453031365434-00000001-part4', path: '/dev/disk/by-id/nvme-nvme.8086-4356463837323236303…54454c205353445045434d453031365434-00000001-part4', guid: '', type: 'N/A', health: 'MISSING', …}
index.e8b7f461.js:29287 Selected disk not found Proxy(Object) {name: 'wwn-0x5000039b38d12099', path: '/dev/disk/by-id/wwn-0x5000039b38d12099', guid: '', type: 'N/A', health: 'ONLINE', …}
index.e8b7f461.js:29287 Selected disk not found Proxy(Object) {name: 'wwn-0x50014ee20b07fa13', path: '/dev/disk/by-id/wwn-0x50014ee20b07fa13', guid: '', type: 'N/A', health: 'ONLINE', …}
index.e8b7f461.js:29287 Selected disk not found Proxy(Object) {name: 'nvme-nvme.8086-43564638373232363030303831503642474…54454c205353445045434d453031365434-00000001-part3', path: '/dev/disk/by-id/nvme-nvme.8086-4356463837323236303…54454c205353445045434d453031365434-00000001-part3', guid: '', type: 'N/A', health: 'MISSING', …}
index.e8b7f461.js:29159 loaded Disks: RefImpl$1 {dep: Dep$1, __v_isRef: true, __v_isShallow: false, _rawValue: Array(32), _value: Proxy(Array)}
index.e8b7f461.js:27500 Traceback (most recent call last):
File "<string>", line 3, in <module>
ModuleNotFoundError: No module named 'libzfs'
getDatasets @ index.e8b7f461.js:27500
await in getDatasets
loadDatasets @ index.e8b7f461.js:29170
initialLoad @ index.e8b7f461.js:29905
await in initialLoad
index.e8b7f461.js:29233 loaded Datasets: RefImpl$1 {dep: Dep$1, __v_isRef: true, __v_isShallow: false, _rawValue: Array(0), _value: Proxy(Array)}
index.e8b7f461.js:29933 Setting up ZFS Notification DBus message handler...
index.e8b7f461.js:29945 Connected to ZFS Notification DBus. Subscribing to Message signal...
index.e8b7f461.js:29951 ZFS Notification DBus message handler successfully set up.
cockpit.js:6 cockpit.format_{bytes,bits}[_per_sec](..., 1000, true) is deprecated.
r @ cockpit.js:6
Hn.e.format_bits_per_sec @ cockpit.js:6
AF @ networkmanager.js:15
qh @ networkmanager.js:17
Au @ networkmanager.js:6
Ew @ networkmanager.js:8
Iw @ networkmanager.js:8
lE @ networkmanager.js:8
md @ networkmanager.js:8
kw @ networkmanager.js:8
Vv @ networkmanager.js:1
jv @ networkmanager.js:1
cockpit.js:6 python3-pcp not installed
$e @ cockpit.js:6
pe @ cockpit.js:6
jn @ cockpit.js:6
dispatch_data @ cockpit.js:4
x.onmessage @ cockpit.js:3
(anonymous) @ cockpit.js:1
postMessage
(anonymous) @ shell.js:104
$e @ cockpit.js:6
pe @ cockpit.js:6
jn @ cockpit.js:6
postMessage
$e @ cockpit.js:6
pe @ cockpit.js:6
jn @ cockpit.js:6
postMessage
$e @ cockpit.js:6
pe @ cockpit.js:6
jn @ cockpit.js:6
postMessage
index.html:10 GET https://nas02.server.adhome.home:9090/cockpit/@localhost/*/po.js net::ERR_ABORTED 404 (ERROR)
cockpit/@localhost/file-sharing/index.html#/:1 Refused to execute script from 'https://nas02.server.adhome.home:9090/cockpit/@localhost/*/po.js' because its MIME type ('text/html') is not executable, and strict MIME type checking is enabled.
garageCliAdapter.ts:110 Garage health check failed: ProcessError (not found): garage: not-found
at s.<anonymous> (index.js:1854:33)
at $n (cockpit.js:1:3294)
at cockpit.js:1:3491
at Fn (cockpit.js:1:2327)
isGarageHealthy @ garageCliAdapter.ts:110
await in isGarageHealthy
(anonymous) @ App.vue:63
(anonymous) @ App.vue:174
callWithErrorHandling @ runtime-core.esm-bundler.js:199
callWithAsyncErrorHandling @ runtime-core.esm-bundler.js:206
(anonymous) @ runtime-core.esm-bundler.js:6280
(anonymous) @ reactivity.esm-bundler.js:1838
watch @ reactivity.esm-bundler.js:1873
doWatch @ runtime-core.esm-bundler.js:6308
watch @ runtime-core.esm-bundler.js:6241
(anonymous) @ App.vue:102
Promise.then
(anonymous) @ App.vue:74
setupStatefulComponent @ runtime-core.esm-bundler.js:7996
setupComponent @ runtime-core.esm-bundler.js:7957
(anonymous) @ runtime-core.esm-bundler.js:5285
(anonymous) @ runtime-core.esm-bundler.js:5251
(anonymous) @ runtime-core.esm-bundler.js:4767
(anonymous) @ runtime-core.esm-bundler.js:6062
mount @ runtime-core.esm-bundler.js:4004
(anonymous) @ runtime-dom.esm-bundler.js:1799
(anonymous) @ main.ts:10
index.js:3937 getServerCluster('ctdb'): File not found: /etc/ctdb/nodes. Assuming single-server.
(anonymous) @ index.js:3937
(anonymous) @ index.js:1618
Promise.then
andThen @ index.js:1614
(anonymous) @ index.js:3931
Promise.then
(anonymous) @ index.js:3929
getServerCluster @ index.js:3961
(anonymous) @ SambaTabMain.vue:42
(anonymous) @ runtime-core.esm-bundler.js:5397
run @ reactivity.esm-bundler.js:237
(anonymous) @ runtime-core.esm-bundler.js:5525
(anonymous) @ runtime-core.esm-bundler.js:5299
(anonymous) @ runtime-core.esm-bundler.js:5001
(anonymous) @ runtime-core.esm-bundler.js:5181
(anonymous) @ runtime-core.esm-bundler.js:4741
(anonymous) @ runtime-core.esm-bundler.js:4924
(anonymous) @ runtime-core.esm-bundler.js:4889
(anonymous) @ runtime-core.esm-bundler.js:4755
rustfsCliAdapter.ts:1324 RustFS availability check failed (admin API probe); checking install/runtime presence: {message: 'Unable to resolve RustFS connection parameters.', stderr: undefined, stdout: undefined, exitStatus: undefined}
isRustfsAvailable @ rustfsCliAdapter.ts:1324
await in isRustfsAvailable
(anonymous) @ App.vue:62
Promise.then
cockpit/@localhost/identities/index.html#/:1 Refused to execute script from 'https://nas02.server.adhome.home:9090/cockpit/@localhost/*/po.js' because its MIME type ('text/html') is not executable, and strict MIME type checking is enabled.
attribution.js:1 Font Awesome Free 5.15.3 by @fontawesome - https://fontawesome.com
License - https://fontawesome.com/license/free (Icons: CC BY 4.0, Fonts: SIL OFL 1.1, Code: MIT License)
index.html:31 GET https://nas02.server.adhome.home:9090/cockpit/@localhost/*/po.js net::ERR_ABORTED 404 (ERROR)
cockpit/@localhost/navigator/index.html#/:1 Refused to execute script from 'https://nas02.server.adhome.home:9090/cockpit/@localhost/*/po.js' because its MIME type ('text/html') is not executable, and strict MIME type checking is enabled.
networkmanager.css:1 GET https://nas02.server.adhome.home:9090/cockpit/@localhost/network/assets/fonts/RedHatDisplay/RedHatDisplayVF.woff2 net::ERR_ABORTED 404 (ERROR)
refreshData @ FileSystemList.f1805631.js:261
(anonymous) @ FileSystemList.f1805631.js:331
flushJobs @ index.e8b7f461.js:2082
Promise.then
queueFlush @ index.e8b7f461.js:1992
queueJob @ index.e8b7f461.js:1987
effect.scheduler @ index.e8b7f461.js:5038
trigger @ index.e8b7f461.js:463
endBatch$1 @ index.e8b7f461.js:518
notify @ index.e8b7f461.js:732
trigger @ index.e8b7f461.js:718
set value @ index.e8b7f461.js:1503
loadFileSystemListComponent @ index.e8b7f461.js:30049
await in loadFileSystemListComponent
(anonymous) @ index.e8b7f461.js:30064
baseWatchOptions.call @ index.e8b7f461.js:5713
getter @ index.e8b7f461.js:1655
run @ index.e8b7f461.js:440
job @ index.e8b7f461.js:1709
flushPreFlushCbs @ index.e8b7f461.js:2020
updateComponentPreRender @ index.e8b7f461.js:5050
componentUpdateFn @ index.e8b7f461.js:4993
updateComponent @ index.e8b7f461.js:4898
processComponent @ index.e8b7f461.js:4857
patch @ index.e8b7f461.js:4431
patchBlockChildren @ index.e8b7f461.js:4738
processFragment @ index.e8b7f461.js:4803
patch @ index.e8b7f461.js:4405
patchElement @ index.e8b7f461.js:4672
processElement @ index.e8b7f461.js:4546
patch @ index.e8b7f461.js:4419
componentUpdateFn @ index.e8b7f461.js:5007
runIfDirty @ index.e8b7f461.js:470
flushJobs @ index.e8b7f461.js:2063
Promise.then
navigationCallback @ index.e8b7f461.js:31504
(anonymous) @ index.e8b7f461.js:24592
cache.<computed>.cache.<computed> @ index.e8b7f461.js:7815
invoker @ index.e8b7f461.js:7372
FileSystemList.f1805631.js:287 Added only datasets from moviespool
FileSystemList.f1805631.js:287 Added only datasets from moviespool2
FileSystemList.f1805631.js:287 Added only datasets from storagepool
FileSystemList.f1805631.js:287 Added only datasets from workpool
root@nas02:~/cockpit-zfs# zfs list
NAME USED AVAIL REFER MOUNTPOINT
moviespool 13.8T 13.0T 185K /mnt/moviespool
moviespool/3D 460G 13.0T 460G /mnt/moviespool/3D
moviespool/animations 1.49T 13.0T 1.49T /mnt/moviespool/animations
moviespool/movies 11.9T 13.0T 11.9T /mnt/moviespool/movies
moviespool2 13.1T 18.8T 185K /mnt/moviespool2
moviespool2/chinese 1.13T 18.8T 1.13T /mnt/moviespool2/chinese
moviespool2/movies 12.0T 18.8T 11.9T /mnt/moviespool2/movies
storagepool 9.32T 6.70T 256K /mnt/storagepool
storagepool/TV 3.04T 6.70T 3.04T /mnt/storagepool/TV
storagepool/ftp 16.8G 2.98T 16.8G /mnt/storagepool/ftp
storagepool/music 1.02T 6.70T 1.02T /mnt/storagepool/music
storagepool/repository 42.8G 6.70T 42.8G /mnt/storagepool/repository
storagepool/test_videos 213K 6.70T 213K /mnt/storagepool/test_videos
workpool 5.77T 5.00T 256M /mnt/workpool
workpool/new_releases 3.54T 5.00T 3.54T /mnt/workpool/new_releases
I hope that’s enough log from the console. Let me know what else you need
