HL8 Fan problem in TruNAS
I have installed a Fully Built HL8 and have loaded TrueNas Community Edition. The unit seems to be functional and serving as a backup device for my HL15. However I have noticed that the rightmost front fan is not spinning. I have checked the connections to both of the front panel fans and they are well seated. I have looked at the Gigabyte Bios panel for the fans and there are entries for the CPU Fan and for System1 and System2 fans. Which fans do these correspond to? Any HL8 TrueNas users can shed any light why only one of the front panel fans is functioning. Both fans run when the system is halted at the Bios level.
TIA for all of your help.
There isn’t anything about a default TrueNas install that would affect the fans, fancontrol or pwmconfig aren’t installed. System1 and System2 should be labeled on the motherboard and on the diagram in the motherboard user manual to trace which fans are connected where.
Although unlikely, it’s possible the system isn’t warm enough to spin both fans after boot. Note that most motherboards don’t have the ability to control the fans based on HDD temps, so you are usually backing into the load on the system based on CPU temp, VRM temp, or something else.
Fans also have a minimum voltage threshhold below which they won’t spin. I’d check your fan curve/settings. What happends of you set both fans to 100%?
I have a few HL15 custom builds running TrueNas and no issues with fans not running.
Thanks for your comments; helpful as always. My experience with the HL15 and TrueNAS is the same as yours. That is why I was surprised to see that a fan was not powered after TrueNAS booted. I’ll have to explore the GigaByte B550i Aorus MB settings.
Update: I have booted into the Bios panel and set the Fan control to PWM from Auto. The rightmost front panel 120mm fan still does not spin even after setting to 100%. The Bios is reporting 0 RPM for the System1_fan. Previously it intermittently showed ~600 RPM. The only changes I made to the Bios was to set the mode to PWM from Auto. It seems that this is a hardware issue.
You can send a note to info@45homelab.com and see if they can diagnose and send you a new fan. What happens if you flip how the fans are connected? Does the problem follow the fan, or the fan header? You can try live booting another OS, but I’m having a hard time imagining it being a TrueNAS issue.
Are there any wires or other obstructions that could be interfering with the fan? Could you try spinning the fan by hand to confirm that it rotates freely?
Also, as @DigitalGarden suggested, could you try swapping the fan connectors to see if the issue follows the fan?
I agree that this is unlikely to be a TrueNAS-related issue and is more likely a hardware issue with the fan itself.
Thanks again to @DigitalGarden and @Hutch-45Drives for your suggestions.
First, a bit of terminology. I will label the Leftmost 120 mm front panel fan as Fan1and the Rightmost as Fan2. As DigitalGarden suggested my next step was the switch the connections to the splitter. I checked again that all wiring connectors were tight including at the Motherboard. When I restarted the system into Bios setup, Fan2 (the problem fan) immediately started but Fan1 hesitated but then spun up. At this point I checked the fan speeds and lowered the System2_fan (40 mm fan) to 2900 rpm to minimize the pulsation noise. I then halted the system and restarted again into the Bios panel. This time, Fan2 failed to start as previous. I looked at the fan speed for the System1_fan header which was 900 rpm (80% PWM) at 46C temperature. I then set the fan speed to 100% PWM, but the speed only increased to 923 rpm. This small increase is inconsistant for a 20% increase. At this point I reset the Fan control to normal and saved my changes to Bios and restarted the system. This time both fans started with some hesitation on Fan2. I let the system boot into TrueNAS and monitored to fans before closing up the HL8. At present after 60 minutes both fans are running with a CPU temperature of 39C in a 25C room.
I concur that the problem is not associated with TrueNAS. I can only speculate due to the inconsistent behavior of Fan2, that either Fan2 could be faulty or the cable or its connection to Fan2 is problematic. Alternatively there may be a voltage problem creating a lack of power to start Fan2. I am concerned also about the limited response of the System1_fan to the PWM speed setting. Note both fans rotate similarly with a bit of resistance at the end of the rotation.
I apologize for the length of the post, but I wanted to provide you sufficient information about my findings.
An RPM of 923 is pretty low even if there is a low noise adapter cable involved (which I don’t know if there is in the build, it would be tagged). Because both fans are apparantly going through a splitter, only one fan’s RPM is being reported and I’m not sure we have ruled out much. It still sounds like it could be a bad solder joint or something on the mobo header, the splitter cable, or the fan itself.
I don’t have an HL8. I assume there isn’t enough cable length just from the fan to go to the motherboard without the splitter? How hard is it to unscrew the fans from the chassis? The next thing I would try is unscrewing and disconnecting the fans from any extension cabling and plugging them each individually into System1_fan and see what that shows as far as power up and RPM. If that dosn’t provide a conclusive Fan1 or Fan2 is broken then there may actually be an issue with the mobo and then I would try plugging each into System2_fan and seeing what happens.
Update on this issue. Troubleshooting with the North Carolina team has established that there is a problem with the System1_fan header. The NC team are researching this at present as there may have been other incidences of this failure. @Hutch-45Drives Some suggestions for the future: 1. a wiring schematic would be most helpful 2. A bit more care in securing the wiring harnesses as I’ve had instances where the wiring bundle shifted and engaged a fan. Also there is an instance of a badly kinked cable.
@phos, thanks for the insightful info. I’ll be sure to pass this off to the team in charge of the quality control of these units!
