This is a general question for anyone with the HL8: What are you seeing for idle power consumption figures?
Hello,
My HL8 with the Ryzen 7 5700G sits at about 18-20 Watts at the wall, at idle running proxmox 8.x without any drives installed. Hope that helps.
It does, thanks. I am seeing roughly the same, maybe a small bit less. But with 2 Ironwolf spinners, 4 SM863a SSDs and 2 Teamgroup SSDs, I am hitting 35 watts with the Ironwolf drives spun down and 42 watts with them spinning. I was a bit shocked that the drives would use that much power
