Ok - I guess you’re on an older version of 45Drives-Tools. It looks like the latest version 3.0.14 did make it into the repo on December 16. Might be worth checking sudo apt update && sudo apt upgrade. I saw in another post where the packages from 45Drives repo were not updating unless specifically called out. I think that would then be sudo apt upgrade 45drives-tools.
This is what I am getting when try to update it.
45drives-tools is already the newest version (3.10.0-1focal).
The whole system was installed 5 days ago so I am sure everything is up to date within 5 days.
I can see why apt would think that based on versioning, but I also see that package was created back in August. There are packages with a creation date after that in the repo so I think this is mistake and probably should be 3.0.10. Maybe try to install the latest package by specifying the version number: sudo apt install 45drives-tools=3.0.14-1focal
